Glad Prototype 2 seems to be going pretty smoothly.I made some more changes - more holes for ventilation.
August will prob be a paper launch, I'm targeting 5-10 pcs, Sep trying to get maybe 100+.
Can’t wait for the temperature results!
Are those 10 models going to be available to the public or are they mainly for early backers/tech reviewers?I made some more changes - more holes for ventilation.
Update 2019-07-14: Prototype 2 photos and changes for production
- photos of Prototype 2 are below
- vent / hole pattern needs to change
- front panel top and bottom ratio need to change
- acrylic window for testing
- need to make a lof of small changes (will make a list *after I finalize the CAD)
The hole patterns are gonna change to the one with high vent. Holes?
What’s the reason for changing the golden ratio on the front top and bottom panel?Update 2019-07-14: Prototype 2 photos and changes for production
Does this mean that the final version will be anodized (or have an option to have it anodized) rather than brushed metal?The machining tool path looks so cool, it's shame I have to sandblast and anodize.
They are all blasted / anodized. he never talked about brushed metal. It looks way to ugly to be honest.Does this mean that the final version will be anodized (or have an option to have it anodized) rather than brushed metal?
Also, prototype 2 looks really good! Looking forward to the final product.
He is gonna do metal yes.A few questions:
- Are you still planning to offer metal side panels?
- When positioned for a two-slot GPU, it looks like the power supply will also move, pulling away from the side of the case. If that is correct, will we need some sort of duct to ensure the PSU fan pulls fresh air from outside the case?
I love everything about this case except for the fact the graphics card will have to be upside down for a top mounted rad. Is there the possibility of their being a top mounted rad version of this case in the future(without an upside down gpu)? With the modularity of the mobo tray, couldn't you get away with just a 2nd back panel design?
Prototype looks good, the changes to vent holes size/pattern will probably make it look even better.
It'd the same layout as ghost s1 and dancase a4. It just pulls fresh air from the side. No need to worrie. It'd not like it needs completely fresh air anyway.
? In the A4, the PSU fan is right next to the side panel...
@Wahaha360, can you address this question?
I've been wondering about the risers and the X570 boards. I know there were issues with the Radeon 5700 cards. Been holding off on picking up a board so far while I wait on the dust to settle on Zen 2 a bit. Bouncing back and forth between the Gigabyte X570i and the MSI B450i.Update 2019-07-15: 3M Riser compatibility confirmed.
X570 motherboard will not work with any PCIe 3.0 riser, so it's a problem for all cases on the market.
Rumor has it that the 3M is PCIe 4.0 compatible (X570 mobos), so I got one to test.
I will have to test, but I doubt it will amount to 1-2C of difference if any.
The adjustment is about 20mm, so you can always use a standoff to push the SFX close to the Side Panel in 2 Slot GPU mode.
Sorry to hear that...Poor X570.Update 2019-07-15: 3M Riser compatibility confirmed.
