    Votes: 117 24.7%
    Votes: 357 75.3%
  • Total voters
    474
Navic
587
1,341
Hey Wahaha, Loque Sweden had a instagram post of this nifty concept stand for the S1 which brings the case vertical. Any chance something like that could be designed for the T1?
Am I the only one that doesn't like the look of that stand? I'd rather just have a case made for the vertical orientation (like the P1, Phanteks Evolv Shift, or the NZXT H1) than a stand add-on that doesn't go well with the look of the case.
robojim
254
222
New York
For those not on the subreddit: I did it!
blindphleb
79
107
I'm planning on wiring a switch to the clear cmos jumper. Does anyone know if the included power switch would be able to be wired for both power and clearing the cmos? Otherwise, I'll use the second hole and use two power buttons when they're available.
DrHudacris
918
1,720
USA
Hmm I don't think you could use 1 anti Vandal switch to do this, but 2 would be easy...just don't mix them up XD
Reactions: blindphleb
V_F
Now the question is: where did you find it??? ?
It was quite late after midnight when I posted in Singapore, sorry for late response..
The radiator was a sample I received from my friend to validate, it's not yet generally available, but he did mention it supposed to be on-shelf sometime (Hopefully sooner but they have teased us for 2 months already so?...)
I've tried it actually ?
Wow nice how well did it fit? And were there any compromises in thermal compared to other common 240 rads?
m0rr13
Sorry if it is a dumb question to ask,
but I have a LT240 AIO and 2 A12x15 fans,
do I need extra screws which are not included in the AIO/fan packaging to mount the slim fans on the radiator and what would the size of the screws be if the answer is yes?
Thank you folks!
kazuma86
276
164
@Wahaha360 I know some users have made some instructions for getting the case put together, but will you release the official instructions before people start getting their cases?
Also, any word on the distro plate and the pump/block combo you sent to @fabio??
Yeah, I'm waiting this too.. Prefer original or official instruction from T1... Also there is no update from @fabio too about pump/block combo.. haha, maybe to busy for him right now..
Reactions: thelaughingman
carrefinho
34
122
do I need extra screws which are not included in the AIO to mount the slim fans on the radiator and what would the size of the screws be if the answer is yes?
Thank you folks!
Edit: Just found some screws in the fan packaging and I guess it would be fine, sorry for asking, thats really a dumb question haha
Not sure what screws you found in the packaging but you should use 20mm length M3 or 6-32 screws. The 30mm ones that come with LT240 will damage the radiator.
Reactions: m0rr13
Wahaha360
a.k.a W360
2,131
10,697
USA
Good call. I've never personally used that so I don't know how much give it has but Phanteks appears to have to have a structure behind it. Not really a fan of that
I don't like the way it looks, so not likely the same way.
Speaker style stand is an interesting idea, but my view should be executed differently.
Wahaha360
a.k.a W360
2,131
10,697
USA
We are little behind on instruction manual with shipping, will work on it *after shipping. It will take 1-2 weeks for most people to get the case post shipping, hopefully we can get the official manual out.
Distro-plate moved to 2021Q1, there is not much point atm. I think I can get hard tube kits for CPU + GPU on the Alphacool Eisstation 40 DC-LT @fabio and @optimumtech is using.
thelaughingman
1,410
1,564
seems like perfect timing for me. distro-plate + freeflow + big navi ?
You need to try this. 240 Radiator, Copper, 25mm thick, extra drain port on the back. Should be similar performance compare to the LT240, better performance than all the other aluminum radiator AIOs, extra drain port for quality of life.
brand and SKU name pls!
NinoPecorino
Tweezer Squeezer
511
516
is this a koolance?
