For the 15mm height fan you can use the following bolt size:
M3 X 20MM
What kind of head is best for this application, looking for something pretty flat
M3 X 20MM
Pan head screws like the screws included with most radiators would be my choice. Unless you’re looking for the top of the head to be flat as well.What kind of head is best for this application, looking for something pretty flat
search for "m3 wafer head" screws to get a thin flat head like an ssd screw. there are sellers on ebay that are extraordinarily cheap. you can find some with a 7mm diameter head. the cheap ones ship from china so it may take a month to get them. here's one link.What kind of head is best for this application, looking for something pretty flat
Those look like Cheese Head screws, but should work too no problem. A bit unsure about the 6.22 diameter, but I’ll measure the fan brackets later to make sure. Or if someone has a caliper and would like to measure the bracket holes exactly, that would be great.
Edit: Wafer head screws mentioned by @NinoPecorino above sound like a great idea if you need the head to be flat as well as thin.
I would avoid those for the fan brackets because they are for countersunk holes. You want a screw that the underside of the head is completely flat.A American source
M3x20 Stainless Steel Flat Head Machine Screw #21599 [21599] : Metric Screws!, We have the screws you need!
Metric Screws! M3x20 Stainless Steel Flat Head Machine Screw #21599 [21599] - Head Style: Flat (countersunk)Head Height: 1.65mmHead Diameter: 5.4mmDrive Type: Phillips Drive Size: Material: Stainless SteelFinish: PlainNylok Thread Patch: Nowww.metricscrews.us
A Canadian source
Machine Screws, Phillips Flat Head, Stainless Steel, M3X20mm
Machine Screws, Phillips Flat Head, Stainless Steel, M3X20mm - $0.48 - Shipping Fee Starting At $4.25 & Free Shipping On Orders Over $89 Before Taxes.canadabolts.ca
I found countersunk screws to work very well, if you only mount the fans to the radiator.I would avoid those for the fan brackets because they are for countersunk holes. You want a screw that the underside of the head is completely flat.
@gwertheim The fan bracket holes are around 5mm. The screws I got are around 6mm and are no good. I would go with 7mm head diameter minimum or 8mm if available for a margin of error.
How hard was it to remove and reorient the the plug? I'm having a lot of trouble with it. Any tips?
Yeah, mine’s a bit like that. That’s the copper. They don’t take too much care with the paint job. Although I’ve heard painting radiators reduce performance anyway, so I don’t know if it’s necessarily a bad thing.
Amazon have it back in stockGot the ones @NinoPecorino recommended now I need to find a set of noctua nf-a12x15 pwm chromax fans
Happen to me also, but still good design.. need improve in QC before shippingYeah, mine’s a bit like that. That’s the copper. They don’t take too much care with the paint job. Although I’ve heard painting radiators reduce performance anyway, so I don’t know if it’s necessarily a bad thing.
I live in Canada and the duties and shipping cost as much as the fan. No thanks
I also recommend the head diameter not be too small. I had to use washers because the head diameter of the ones I got were too small for the fan brackets.
My digital caliper needs new batteries but I think about 7-8mm should be good.
I was recommending 7-8mm screws in relation to the fan brackets only. The screw head of the 20mm screws I have is about 5-6mm in diameter and might not grip the fan bracket correctly if not very careful as shown in the picture below (It could fall into the fan bracket slot when tightening).The screws I have are the cheapest stainless steel flat heads M3 x 20mm screws from Amazon (less than $3 shipped). They have a head diameter of 5mm / 3/16" and "countersink" almost completely flush into the fan housing. Considering the load and amount of space we are dealing with I went with less protrusion over technically correct. I don't have the case yet so I was planning for the unknown. To me, this is perfect. Btw, I arrived at the length by measuring the shank length on the screws that came with the LT240, then subtracting the difference in the fan thickness. This way all of the screws go in the same depth and there is no risk of damage to the radiator..
See I need this case stat, my test bench is getting dusty.
@biggieprollz
This is the riser included! R33SF-TU of 20CM! BUT, as suggested, these are Gen3 riser, you have to try to force your motherboard to use the PCIe slot at Gen3.
Here the link.
PCIe x16 Extension Cable
PCIe x16 to x16 adapter for graphics video cards extension. design for ITX motherboard and chassis mini pc-casewww.adt.link
But you can try also the Link-UP Ultra 4.0, they say it's certified for the Gen4. (I am confident that the 25cm will work here, but maybe take the 30cm to be sure!)
Or the 3M, that it's an amazing riser that it Gen4 compatible (Only 25cm, so it's a super tight fit - I just placed them closer)
8KC3-0726-0250 3M | Cable Assemblies | DigiKey
Order today, ships today. 8KC3-0726-0250 – 164 Position PCIe x16 Receptacle to Card Edge 0.820' (250.00mm, 9.843") Silver Shielded from 3M. Pricing and Availability on millions of electronic components from Digi-Key Electronics.www.digikey.com
Here a picture of the 3M and the Included one
