I know!! I didn’t try with other fittings (maybe some Koolance or in general low profile 90 degrees fittings will do also the job), but this was the only way I was able to fit the Eisbaer LT in the Gigabyte on my build:Bit of an odd question, or a specific one I guess.
Has anyone had any luck mounting the LT240 cpu block on a Gigabyte x570i motherboard?
I have currently got ek fittings on my LT block and it will not mount due to the chipset/m.2 heatsink.
Trying to get some of the stock diameter tubing so I can use the Alphacool fittings over here is becoming a joke. To the point where I ordered some off aliexpress and it simply hasn't shown up months later.
Its getting close to the point of my just buying a pump, ek cpu block and going custom haha.
Production - FORMD T1 (READ FIRST POST)
I am using custom tubing! It's because a lot of things actually: the socket in this MB is lowered, but mostly because you have only 2 "good" orinetation to mount the block. With the fittings facing the NVME SSD/Radiator, the screws to mount the block doesn't allow to rotate enough the 90...
smallformfactor.net
