    Votes: 117 24.7%
    Votes: 357 75.3%
  • Total voters
    474
Daemos
108
50
Nope. The only one working with the slim fan below is the one included. I try to explain it by images on Monday ??
Ah it seems there is no way to get a 240mm rad + slim fan with the 3m riser unless if the 20mm thick rad + scythe slim fan combo allows it.
Gerold
160
172
Austria
www.instagram.com
I ordered, later I will say an opinion, if anyone is interested
be careful, or you are gonna burn your wifi card with these. They are not meant to be used for 5ghz wifi. It's meant to be used for wireless analog video connection. There are some statements online why this wont work.
0Zx
52
123
@pslate T1 flipped orientation PSU cables arrived today.
Edit: I need to clean my piano. Stop judging me.
DrHudacris
918
1,720
USA
We will have to wait and see the pictures @fabio posts about it, but my understanding was the fan can't be between the radiator and motherboard because of the riser, but you can still use the 3M riser if you have the fan between radiator and panel.
Reactions: fabio
tyen
41
180
NZ
Is there an update on the power button shipment?
I've been using a temporary one from my Dan Case for the past couple months. But I intend to sell that case so will need a replacement.
Edit: I intend to sell the Dan Case, not the T1
PBJ
358
546
@Wahaha360 shipped it to test shippers last Friday. There was an update about it last week.
PBJ
358
546
This post? https://smallformfactor.net/forum/t...rmd-read-first-post.9933/page-336#post-200538
I assumed that this just meant the shipment was being planned.
Sorry for derailing the thread with the question. I should have contacted Wahaha360 directly.
It’s a valid question and you’re in the right place! I’m happy to help.
You’re right though, it doesn’t definitely say it was shipped, but I got a notification from my postal service last Friday that a package from China is on the way.
theexplainer
90
187
picked up a different taoglas antenna that covered the 5.8ghz band (the button antenna only supports 2.4ghz), and wanted to throw a pic ya'lls way to show how it compares to the antenna that is commonly recommended on r/sffpc-
it is pretty expensive for a pair of the antennas (~$25), but good lord the signal is 10x better than the old ones (for at least bluetooth). before, with galaxy buds and the bt card on an asrock z390 itx, i couldn't walk into my utility closet ~30 feet away without the audio glitching out. now, i can a) walk into the closet and shut the door to it behind me (heavy door) and audio still be clear as day, and b) leave my apartment, shut the door behind me, and walk ~90 feet down the hall to the elevator bank before audio starts to glitch out (probably due to the elevator support structure).
i was also able to take a bluetooth keyboard into my utility closet, shut the door, and type this sentence out from there (when before i couldn't maintain connectivity for more than 15 feet of unimpeded air), so the improvement is no joke.
10/10, would recommend if the green color doesn't bother you.
where did you find those? I had to contact a manufacturer and let them produce some to my liking - Once they arrive I'll post pics of them, aswell
fabio
1,885
4,325
No, you can have the 240 with the slim fan with the 3M, but in that casa the radiator should be “inside” and the fans against the top panel.
natefaso01
I've been lurking for almost a year now. I just want to say bravo to the guys who put this case together. It seems to undercut everyone on price while beating them in cooling and build quality. The fact that they plan to continually produce so I can actually get a hold of it at some point it is just the icing on the cake! I will probably end up waiting till the initial rush is over to finally purchase it, but I still pumped!
Daemos
108
50
Ah okay. So then 240mm rad with two slim fans from noctua or scythe.
I wonder what would perform better a 240mm AIO with two slim fans or a 120mm AIO with a normal sized fan... I'm looking to cool my 3700x only... But possibly upgrade to the zen 3 version of the 3900 or 3950x...I doubt I would try GPU water cooling unless if RDNA 2 is super efficient.
gwertheim
938
1,555
Any information about the exact date of the beginning of preorder ?I can't wait for this case any longer?
We don't know the EXACT date so you will just have to wait longer. If you can't wait any longer and need it right away (which I think is more of a want but what do I know) there are plenty of other cases which are ready to ship.
@Wahaha360 will announce when the case is ready and the store is open.
