From his side, you can only have the 25mm fan with the radiator against the panel, so...That's what I figured, just when @theexplainer said @DrHudacris was right with "panel-fans-rad" the description of the fans didn't align![]()
ah sorry, I got confused a bit, I meant - Mainboard-Fans-Rad, there is no way to mount the 25mm fan between the rad and the panel.That's what I figured, just when @theexplainer said @DrHudacris was right with "panel-fans-rad" the description of the fans didn't align![]()
I am moving my pc to a sff. As I will be moving around for work now I want it to come with me. I see this case and it is all I am after for the case. Would like to know how I can get my hands on one, contribute to this
You were not mistaken. It was precisely your asking about where to get it that provoked the wrath of certain members.AHHHHHHH
I just realised my post above was in reference to the chinese one! No I am after the Formd T1. I have all my parts and sitting in a phanteks p400a until I can get a formd T1
I just saw someone in China was inspired by your build:
www.chiphell.com/forum.php?mod=viewthread&tid=2219940
Check it out
For 1 240 rad two GPUs (the most hot chip in the system) will be too much!Dual GPU? Why? And why not liquid cooling both? This looks so well thought out but this is strange to me.
The messages after that post determined the issue to be the plasticizer from the old PVC tubing that was used in an early version of the kit. PVC tubing has since been changed to rubber tubing in newer versions of the kit. Your first step is to determine which tubing you have, then change the tubing if necessary. There is no galvanic corrosion issue from mixed metals with this kit to my knowledge.
The new version with the RGB Bear is the only one that comes with the improved TPV tubing.Has anyone recently purchased an LT240-- perhaps from Aquatuning.us-- who can verify the below message from a couple of months back?
Does new stock indeed come with rubber tubing now by default?
It’s set to release this summer, officially called Eisbaer LT Aurora
Per a quick Google search, I found that the pump/CPU Block height is measured at 69.9mm, possibly not including the inlet and outlet fittings on the top. I have difficulty visualizing this fitting in the T1. I might be wrong, clearly, as I have never owned or seen their prior product. I would think that using the Eisbear LT Solo would make more sense. Again, more experience people, please feel free to correct me. ?The new version with the RGB Bear is the only one that comes with the improved TPV tubing.
DOOH! Dummy that I am, I remembered seeing that Facebook post recently. Looked at the picture just now and saw that the pump/cpu block looks just like the Eisbear LT Solo excepted for the RGB vomit (not a fan). That should not be a problem fiiting in the T1.Far from experienced here, but I suspect you might be confusing the (IMO pretty confusing) product naming. Or at least I personally did so earlier.
There's the Eisbaer Aurora RGB that currently shows up even when you search "Eisbaer Aurora LT" I can't seem to find anything about the Aurora LT. If not for the tip way back in thread to check Alphacool's Facebook page (link to teaser post), no one would ever know hahah
Anyhow the linked post pictures what looks like a pump block a lot like the "old" LT 240 to my eyes EDIT: excepting the frickin RGB bear of course, lol
SO @fabio, I have definitely followed this forum as well as time permits, and had read your comment in this post several days ago. I would like to know if you have actually run your system on air-cooling alone. I am asking since I currently run a 9900k/2080Ti on air, with dual case 120 intake fans for the GPU and a Scythe Big Shuriken 3 for the CPU. My case is a Silverstone RVZ01 (14 liters) which has excellent airflow, but pushing my CPU on synthetic testing leaves me unhappy with temperatures climbing very rapidly to just above 100C, which leads me to quickly cancel my testing. I am curious if I should start pre-ordering water-cooling parts, as I had planned, or whether the airflow in the T1 is just that good? My GPU temperatures are never a problem.Guys, I could seem crazy but I know more or less the meaning of space optimisation (and if it is worth the effort!) - I'm an architect BTW.
But you are way beyond me! ? (In the S1 I have no clue where you want to put the second rad.)
My raccomendation with a powerful GPU (that you don't mind to reach 75C degree under gaming) and a powerful CPU, is a 240rad only on CPU and a GPU on Air.
If you don't need multicore sustained performance, and want something quiet, you can watercool the GPU with the small Eisstation DC-LT-40 pump and stay on air on the CPU.
THE BEST option for 98% of the people is GPU on AIR 2slots and CPU with the L12S/Blackridge/BS3 plus 2 fan on top to exhaust.
Well, I've tried that configuration in other case, like Steck, Ghost, MI-6, and with the great airflow in the T1 can only be better!!SO @fabio, I have definitely followed this forum as well as time permits, and had read your comment in this post several days ago. I would like to know if you have actually run your system on air-cooling alone. I am asking since I currently run a 9900k/2080Ti on air, with dual case 120 intake fans for the GPU and a Scythe Big Shuriken 3 for the CPU. My case is a Silverstone RVZ01 (14 liters) which has excellent airflow, but pushing my CPU on synthetic testing leaves me unhappy with temperatures climbing very rapidly to just above 100C, which leads me to quickly cancel my testing. I am curious if I should start pre-ordering water-cooling parts, as I had planned, or whether the airflow in the T1 is just that good? My GPU temperatures are never a problem.
Thanks, bro! I thought it was a button with an actual "NFC", like turning PC on with my phone... Well, joke's on me, lol.Sure thing! It’s a premium 16mm vandal switch with very bright white LED illumination. Here’s the link.![]()
The people that bought it in China got the power button with their cases, but I don't think any test shippers got the buttons shipped to them. I haven't gotten one, but it's no big deal because I got one from pslate and it works as expected. It's longer than the one you get with the T1, that's for sure, but it's perfect otherwise.Hi there!
Between life and coronavirus I have been busy with things.
Did the power-on button ever get sent to people?
