I have to check first without the flow meter, having a simple or straight curve. Then I will try without the quick disconnect or with a different model.do you think with a tubing run similar to what Optimum tech did it would be fine?
SO, It's the radiator actually that is not cutting the CPU (16 core) and the GPU (Titan RTX). I will try the same configuration (Maybe one pump only??) With the EKWB SE Classic to have a double check!
I MEAN, it's super ok, but I would like to have the delta water temp 3 degrees less warm.
With only the CPU I am pretty sure it will be ok. (I will not try it because I don't want to put again the stock cooler on the GPU)
I didn't test the GPU, in general never went above 63 in every configuration I did. (With better rad stay at 56 under load, just FYI).What were the final temps for both the cpu and gpu? I can only see the 45c for the gpu.
Are your fans not blocked in this configuration?
Of course It's flipped compared to the picture. That was to show what I was doingAre your fans not blocked in this configuration?
