I need some break for this thread, since i got dreaming about T1.. Need some relaxation.. >_<
Tbh that seems kinda niche within a niche.Since there are a single slot cards like the quadro’s , what you think guys if there is the option to shrink the gpu place to a single slot to make enough room from a higher cpu cooler ?
Just an idea on my mind .
Nothing wrong with that.
I’m taking a break too ?
raise this topic to the top !!!!!!!!!!!!!!
need 1000 pages haaah !!!!!!!!!
Bro. What happened to taking a break from the thread lol. You literally talked about taking a break a few hours ago. Take a break, you've been very active on this forum. Binge watch anime or something, just try not stress yourself over this case.@Wahaha360 will T1 get a bag for mobile activity?
Wow 301 page 6001 posts, this thread gonna make some bigger move![]()
Actually i need to finish my proposal and here I'm lurker another thread and watching Friends >_<Bro. What happened to taking a break from the thread lol. You literally talked about taking a break a few hours ago. Take a break, you've been very active on this forum. Binge watch anime or something, just try not stress yourself over this case.
I bought all my parts in preparation for this case. I was really lucky to be part of the China batch. I guess many people just weren't that lucky.
Tl;Dr: take a break and don't stress yourself over this case.
What kind of spam? If you are spam, then I feel sorry for you
AGAIN, another iteration of my build!
This an option where you can have an external D5 pump and reservoir, using Koolance QD3 Quick Disconnect fittings for easy moving around and placed on an EKWB Vertical Universal 120 mount where I've added some small feet.
The tubes just go out from the empty PCIe slots on the back.
I've replaced the previous flow meter with an Aqua Computer MPS 200 (It is thinner, has an integrated water temp, and is connected through an usb header, so the connector now allows me to close the panel completely! - for the D5 and a full power DDC is better to get the 400. With the 200, that have a max measurable flow of 200l/h, the pump at 60% completely saturate it ? )
I've switched back to a EK Coolstream PE240, loosing 3/4 degrees of cooling performance but I like better the proportion!
(At 4.3ghz on all core, Blender benchmark test, the max temp is 70 degrees after 30 minutes, so I am pretty happy!)
Too keep the panels more secured, I think I will get some button strong magnet. For now I am using a magnetic tape as you can see!
Cheers!
I have read through this entire thread twice now and there is probably a total of close to 30 pages where the discussion is off topic and does not belong which makes it very hard to find information.
Someone heard about Comino OTTO case?
