Well, My idea to fill the system from the GPU top part has half failed. There is too much pressure and the water can spill out. I think I will place a T fitting plus a valve...
How does one have the time and dedication to do this stuff lol. I can't focus on anything at all and whenever I try focus on something I end up rewatching all 7 of RWBY. I watched like 30-40 hours of tv in 5 days.Well, My idea to fill the system from the GPU top part has half failed. There is too much pressure and the water can spill out. I think I will place a T fitting plus a valve...
Hobbies are healthy. Nothing wrong with it. Sure it's expensive but drugs and cars are way more. Plus this hobby, unlike a lot of people without them, has benefitted all of us a ton during these weird times. I think @fabio is goodHow does one have the time and dedication to do this stuff lol. I can't focus on anything at all and whenever I try focus on something I end up rewatching all 7 of RWBY. I watched like 30-40 hours of tv in 5 days.
Im just saying, I admire ur dedication but I think you might need to get a mental health check to see if you have a spending problem.
I think tinkering with hardware and searching for solutions to a problem is far more healthier than watching 40 hours of TV in 5 days or not being able to concentrate on something harder than 7 seasons of anime. No offense.How does one have the time and dedication to do this stuff lol. I can't focus on anything at all and whenever I try focus on something I end up rewatching all 7 of RWBY. I watched like 30-40 hours of tv in 5 days.
Agreed. I will say though I was so caught up building my PC the last few days I had been forgetting to eat and drink lolI think tinkering with hardware and searching for solutions to a problem is far more healthier than watching 40 hours of TV in 5 days or not being able to concentrate on something harder than 7 seasons of anime. No offense.
Can this thing control the fans based on GPU temperature, and possibly even VRM temperature as well? If so it looks like just the thing I've been looking for
Sent a ticket to EK about their new AIO
Personally i tend to have a spending problem, but this ain't it my friend. Pc building is not just a hobby, it is a culture. Also, with the technological advance thet we are living, i personally feel that am not exploiting it to full potential and i feel bad about this. Watching TV on the other hand is a loss of time. Please, i am not judging, i watch a lot of tv myself. During this couple of years i might have spent more on gpu s than on smartphones..but a gpu has a longer lifespan, so it islogical i think.How does one have the time and dedication to do this stuff lol. I can't focus on anything at all and whenever I try focus on something I end up rewatching all 7 of RWBY. I watched like 30-40 hours of tv in 5 days.
You know what's even more work after you're done? Making extensive parts lists for every build you've done.(Damned the XE, I was really looking forward to see it's performance!)
Testing the system a bit and then I'll fill it!
Added an AquaComputer flow meter, swapped the DDC 3.25 (I think it has an issue with the RPM, I cannot red the speed or change the PMW through the QUADRO) for a EKWB MX 3.1 PMW.
One of the two AquaComputer thermal sensor was broken, so I had to replace it as well (today maybe was better to stay in. front of the TV, really!! ? @Proflucifer).
Add the fill/drain valve as well.
I'VE finished the zip-tie! Hoping will be not needed! ?
Well, I hope others will do the same! Thanks man!!You know what's even more work after you're done? Making extensive parts lists for every build you've done.
I will measure later when it will be quite the backgroundCool build. How's the pump noise?Production - FORMD T1 (READ FIRST POST)
Now it's leak free ?? Well, My idea to fill the system from the GPU top part has half failed. There is too much pressure and the water can spill out. I think I will place a T fitting plus a valve...smallformfactor.net
Much nicer than SpeedFan@Navic ANd you can also create a virtual sensor based on formulas! Here mine for the DELTA Ambient Temperature-Water Temp Average.
So you can setup the fan curve based on really a lot of thing!
