Why would it be?Would having an m.2 ssd on the back of a motherboard be a bad idea in the T1?
It may get a bit warmer due to the sandwich layout of the case (like any other sandwiched layout), but other than that you should be good to go.Would having an m.2 ssd on the back of a motherboard be a bad idea in the T1?
You didn't link the correct one. That's the Eisbaer 240, not the Eisbaer LT240, comes with with a 30mm radiator and a pump that has tubing the most likely wont fit. Now you can change it out for 90 degrees and maybe it will but I'm doubting it and the radiator "won't" fit. I've been looking for the LT240 for a few weeks in the US and no one has had any stock. I'm sure they will come back within a few months.![]()
Alphacool Eisbaer 240 CPU - Black
With the “Eisbaer”, Alphacool is fundamentally revolutionizing the AIO cooler market. Where traditional AIO CPU-coolers are disposable products which are neither upgradeable nor refillable, the Alphacool “Eisbaer” is modularly built and can be upgraded, rebuilt or refilled at any time. This...www.performance-pcs.com
Do you have any specific sites? I know amazon.ca had like 10 in stock sold by alphacool but they weren't shipping to the US at the time I was looking.My bad. Maybe check the Canadian sites. I found plenty north of the border
which website did you order from?
I ordered from Digi-Key. I use them a bunch for other stuff and they're reliable.
Cable already shipped and should be here tomorrow. Will share some pictures when I install.
Actually I was using the 250, but is super tigh. You need to bend it super close to the ends. As I’ve said, the 300mm in general is a better choice!IIRC, the ones on Digikey are 250mm including the ends, which makes them too short. fabio is likely using the 300mm that comes with A4-SFX.
The 300mm long 3M cable needed is not a standard part. Maybe it will work, do let me know. I'm kind of curious.
Concealed screws are a big plus.2020-04-12 Update: Distro Plate for DDC, SPC / P5 Pumps
The last picture of Distro-Plate variants is curtesy of Metroversal
Looks like a Leather/Leatherette texture.Concealed screws are a big plus.
Second from the left: Is this just like the normal front?
My experience is with the NZXT Kraken X52 and the Corsair H60Well... it is avoidable. At least to make it inaudible to human ears.
Like Magicool did with their DCP450.
All three units I did builds with are totally inaudible out of the box.
You can literally hear nothing even with your ear right next to the pump.
No comparison to any DDC or D5 I ever used.
So saying it's unavoidable is just not right
Edit: The only thing I would do, using a DCP450 is to replace the original o-rings with better versions. Some people reported issues with the original rings.
With my experiences and those in this thread, a pump will be mostly silent if you get one with some amount of control.
To my knowledge no one has attempted putting an SFX-L in the T1. 180 flipped is totally a no-go, but in standard orientation, rough calculation assuming 50mm rad + fan under the PSU leaves you 20-25 mm for the cables. So it's in the realm of extremely difficult, and barely feasible. Which looks to be right up your alley![]()
I've tried that route also, it did not allow the option for shipping to the US. I'm in the same boat as @pwnedunies. I'm have most of my parts for my future T1 build except cooling options. So hopefully they come back into stock before the T1 is available.![]()
Alphacool Eisbaer LT240 CPU All in One High Performance Water Cooler, 240mm Copper Radiator - black (11445) - Newegg.com
Buy Alphacool Eisbaer LT240 CPU All in One High Performance Water Cooler, 240mm Copper Radiator - black (11445) with fast shipping and top-rated customer service. Once you know, you Newegg!www.newegg.ca
