I was never quite clear on it: will the H60 fit in the case, or were you just using it as a reference point for cooler performance?
It fits
I am happy with my current ATX tower but is planning on upgrading with Ryzen 3000 in an ITX enclosure. I'm targeting at least 8 core @ hopefully 5Ghz all core. If Ryzen disappoints then I'll go 9900K.
For GPU probably 2080Ti, so 3 slot would be nice. For temps I'm an as low as possible in a given size kind of guy, as long as the noise is not unbearable.
I'm confused by your use of Positive and negative air pressure orientations. Do you mind explaining? I don't mind negative air pressure. I'm just looking for rad on top for best cooling and smaller piece front panel on bottom for better looks.
Also I think I'd grab the TX240(or that sweet Aijia really, not that I could source one) just to avoid those ugly tubes on the LT240; the temps seem close enough.
Any news on the Fr33Flow 48?
I see now. Thanks for the detailed explanation!Radiator on the bottom is Positive Pressure orientation (your preferred orientation for looks).
Radiator on the top is Negative Pressure orientation, aka exhaust mode
The smaller piece you are referring to is the Front CNC Chassis, the larger piece is the Front Lid.
The Front CNC Chassis provides structural support for the radiator / AIO / fan, so it must be aligned with the radiator / AIO / fan.
Since you like the look of the Positive Pressure orientation, I would tell you to get the Alphacool LT240, b/c I suspect a 240mm radiator = flipping the case will not yield more than 2C of temperature difference. That's the best solution.
Is there just no chance that you'll make this a recurring product like Ncase M1 or Dan A4? Your decision obviously, but I feel like it's such a great design, it'll be a shame to just be an one time limited run.
I don't want to put the horse before the carriage, I'll deal with that after batch 1.
Didn't realize this was a one and done run. What's the plan for people interested? Will you be making a finite amount and selling until oos, or is the plan to do a pre order?
Update 2019-04-10: case named: T1
@CircleTect said the prototype looked like a terminator. So T1 it is then.
So this is not going under the NCase brand then I guess due to Necere not being the main designer haha. I guess it is all under a SFFLAB brand with the different case types as revisions a la Silverstone.
Compared to the SM550 I'm interested to see how the L12S with fan, and 2 120mms on the bottom will do against it as it seems to really help out even with no fan. At what point does watercooling in a limited space become no longer worth it? But also maybe that's just me and my preference towards air.
SFFLAB is not a case or product brand, and it should never be - that was never the goal.
SFFLAB is more about splitting rent on web dev, shipping and some manufacturing.
So this will be sold under the Ncase brand?
