    Votes: 117 24.7%
    Votes: 357 75.3%
  • Total voters
    474
bynio
70
74
I've finally got an info on my package (Poland). It's a request for additional documents.
There are two separate sections, one for individual customers an another for companies.
In my case (pun not intended) as a individual there seems to be to additional options:
1. For internet auctions a print screen and something proving it was payed, so could be screenshot of statement on the account or invoice.
2. For all other invoice should be enough.
It should however be translated and signed by a translator. Not necessarily sworn.
Now I probably shot myself in the foot here because I've paid with an UK card that is closed now, but that's on me.
As for the invoice I think I've only received an email, so I will either print it out or @Wahaha360 can provide me with pdf. I don't know what documents are included with the package.
Cronos83
71
102
43
Germany
Now I know which one I had in mind...
The Magicool 240 G2 slim.
That one is 272x120x27mm and should fit with the Noctua slim fans.
The cooling performance of the G2 slim is quite good (better than the LS240 OEM but slightly worse than a normal Black Ice).
Think I'm gonna try the G2 slim.
fabio
1,885
4,325
Trying to figure out the best orientation for the PSU for this configuration... Any suggestion?
Maybe the 180 degrees is better?
I need also to think where to route the PCIe Cable. I am trying to double crimp to have custom cables, but maybe I will end to use the one that corsair provide with the SF750...
The riser I am using at the moment block the radiator fan. Maybe I can flip the rad and fans?
DrHudacris
918
1,720
USA
There is very little space for cables in the 180 orientation, I measured about 26mm. You have more room in the default orientation. Plus you can use a fan grill on the fan under the PSU! Maybe.. unsure of clearance.
gwertheim
938
1,555
I took my own with string (EVGA GM, default orientation, with strix z370)
24pin 150mm
CPU 260mm
PCI 180mm
I was asking pslate because his cables are really good and if he has his measurements, you can start ordering from him. I got a set from him for my ghost and he let me send off menu materials to his place and the cables came out looking perfect
DrHudacris
918
1,720
USA
Oh I gotcha! His shop appears to be closed for new orders now! I can speak to the quality of his work, too. Sleeved set in my SM580 and unsleeved in ghost.
sffinxs
You can shift the GPU riser to the second slot to give you more space. I have done this in my build, so it's definitely possible.
Thank you for the tip! I did not think about that. If I understood correctly, that means the motherboard will be in a triple-slot GPU configuration, but the GPU riser will be set to the second slot to leave space (one slot) between the motherboard and GPU. Ingenious :).
Reactions: DrHudacris
cldskt
34
29
@pslate when do you think you'll have cable measurements for the t1? Is it similar to the ghost measurements?
I have the @pslate one for the Ghost, and they are perfect! Just the CPU one should be 2cm longer, IMO.
EDIT: Working on it...
Fabio stated that the Ghost's measurements fit well, with the exception of the CPU one to be 2cm longer. Still awaiting pslate's own measurements too!
DrHudacris
918
1,720
USA
You could, of course, use the motherboard in dual slot mode, and still shift the riser to the second slot. You would be limited to single slot thickness expansion card though!
Thats actually brilliant. Probably fit a 2.5" drive in the gap also?
If you can fit it around the riser, yeah! The riser will be stretched rather tight.
gwertheim
938
1,555
Which is why I want to double check because pslate has experience with all the sff cases
Reactions: fabio
Vaux
96
123
Actually you have plenty of space, because you have nothing on that side of the motherboard, and you don't have to suffocate your fans
Thrusher
26
Poland, Warsaw
This case looks amazing. Is there any chance to buy it before official launch? Right now I have my PC in Sentry 2.0 but I want something with lower height and I want to have option to use 3 slot GPU.
