Havent been able to find rubber 11/8 tubing. Well thats not true. Fuel line hose for cars is generally 8mm. Not sure outer diameter. But fuel line wouldn't have the flex needed for the bends and probably not have the give for the fittings to seal.No, the stock fittings use 11/8.
Sorry, but are you in a manufacturer team? Because I received the case without power button. And I don't complain, because initial offer clearly stated that it will be without, and I accepted it. With pleasure.Power buttons will be delivered with the case. Other options would be some custom ones, for example pslate comes to mind
Sorry, but are you in a manufacturer team? Because I received the case without power button. And I don't complain, because initial offer clearly stated that it will be without, and I accepted it. With pleasure.![]()
I am not quoting You on that, but if they are coming I will be waiting for sure! No vandalism.@Wahaha360 stated previously that the power buttons didn’t arrive in time to go out with the test shipments, but would be shipped to test shippers separately. So it should still be coming theoretically. Alternatively you could order a vandal button from elsewhere.
It is for mounting PSU 180 degrees.I couldn't figure out what this plate is for. Initial thought is that it is for the cases turned upside down. Can anyone correct me please.
Thank you, thought it might be the case. Why so many holes in between then?It is for mounting PSU 180 degrees.
can anyone with the case provide some information about the mesh side panel? what is it made of, the thickness, the hole sizes? I wanted to make one for my case, wondering if it is possible to make one/find a place to custom one for myself. appreciate it.
Wahaha360: Sorry for asking, I have not followed this thread but I really like the case. When and where can we pre-order? Thank you!
BUT it's true, that I've never used the stock tubes! If here is the problem, just change tubes! From 8/11mm to 13/10mm there will be no issue inside the FormD T1.
They are threaded (the own that support the PSU bracket at least), that what I used in my configuration (editEaster egg feature for mounting PSU in 90 degrees, but you'll need your own nuts or something because the holes aren't threaded. I just went back and looked for the posts mentioning it, it's around page 195-196.
Bought some CKC form alphacoolWhat water do you guys put into the loop, do you buy it pre mixed with shit from places like micro center or ek, or do you do your own thing, if so what do you use?
They are threaded (the own that support the PSU bracket at least), that what I used in my configuration (edith you talked about the middles one, sorry read to fast)
The parts that I have no idea of why they exist are those ones:
I think he was talking about the L shapes ones (since that's their purpose) and not those onesSorry, I don't know what those are for...back on pages 195-197 somewhere, @Wahaha360 mentioned they are used to secure GPU hold down bracket but those are threaded already. Maybe I'll figure it out as I finish the build.
The small pieces are to offset the gpu riser, in a completely NOT supported configuration of bifurcation.Sorry, I don't know what those are for...back on pages 195-197 somewhere, @Wahaha360 mentioned they are used to secure GPU hold down bracket but those are threaded already. Maybe I'll figure it out as I finish the build.
Suggested revision of radiator/fan bracket: extend the slow of the read bracket and shorten the slot of the front bracket. In the instance of using thicker (not supported) radiators, only 2 screws can be used to secure the radiator. With this small change to the brackets only (looks like steel sheet), other radiators can be officially supported? In my opinion, fans between the panel and radiator are the way to go for all non LT240 radiators. Pictures to illustrate:
Would straight distilled water work in the loop, or do I need to add more?
My first build with it was to exactly reuse the tubes, just having cut them to fit my needs.
The second build was made using Barrows 13/10mm fittings and of course other tubes.
I’ve never kept the original QuickDisconnect.
