Exactly!Ok good information.
So to be clear. There are no issues with mounting AM4. No need for noctua mounting?
Intel is the issue?
The issue is with the Alphacool INTEL backplate.
Intel is the issue?
RIPExactly!
just done some testing, to be more precise, played a little in a Fallen Order, apart from that, tried to measure noise level with my phone. As result:I would really appreciate it! I plan on being on air cooling for the foreseeable future until there is a distroplate.
RIP
#teamred
(But the Kelvin t12 doesnt come with am4 mounting so I gotta buy a bracket... rip)
Thanks mate. Been looking into it. Gonna see if I can modify the stock am3 one first. But I dont think there is enough meat.
www.au.aquatuning.com
Well, finished my T1 build, it took a lot of time, but i'm pretty happy with it, at least because everything fits nicely. It's not a final version, as I already have an LT240, and just waiting while SF750 will return to stock. GPU is also non-optimal for this case, as I have to move the rear part with connectors closer to the side a bit, but it was only 2mm, so nothing critical imo.
The case itself is very high quality and made with a high precision, except for one point, which is the rear top GPU cap, I had to apply some force to fit it in place, and it's not possible to get it back without a screwdriver, which left some scratches on the rear panel, they are not visible while cap is installed, so I don't worry about it. I think that reducing the cap height for a 1mm should solve the problem. Also I do not exclude the case that I did something wrong, and that's not an issue at all, but I haven't found any other way to install the cap.
Regarding the shipment, package was valued at 47 USD so no fees were applied at all, I just got it from the local post office. Outer box was in a very good condition with only some minor dents on angles, inner box and the case itself was in perfect condition.
I think I'm gonna go with a TX240. So it would be. Panel>fana>rad. Since the tubing will need to make a 90 degree turn I am looking at angled fittings. Plenty of rotoray 90 degree fittings. But concerned they'll be too tall.
Anyone know if there fixed rotation fittings will have enough angle to clear the rad?
Alphacool HF L-connector G1/4 outer thread to G1/4 inner thread - deep black
Alphacool-Anschlüsse gehen neue Wege in Form, Verarbeitung, Farbgebung, Vielfalt. Die absolute Neuerung ist ein überragender Innendurchmesser, der das Wort Highflow auch wirklich verdient! Die ersten 3 Farben, Chrome, Deep Black und...www.au.aquatuning.com
Not Yet! It has been cleared by the customs. So I expect to receive in 2 days max!@fabio have you gotten your T1 yet? I want to see what crazy build you do lol.
Absolute mad lad!! ?IF only ASUS was allowing a Bifurcation I could have tried to have 2 GPU and 1 CPU cooled by one 240 RAD![]()
Well, The build will be more or less the same I put in the Ghost! But I will try to put a DDC and an AquaComputer Quadro if I can!
I'm running it as intake and bottom noctua fan as exhaust, I think that I can improve the temperatures by flipping the case, but then I also need to flip the PSU which is not possible for me, so i'm fine with my setup, as it's temporary until i'l get an SF750.Did u run your L12S fan as intake or exhaust? I find that if I run it as intake, with the same cpu temp around 55 c during gaming, fan speed is about 50-60% when using fan as intake and will increase to 70-80% when using as exhaust. Using fan as intake does heat up the case a lot even with a exhaust fan.
Unfortunately for those planning to use the L12S, this is the only way to mount it (with regards to the heat pipe orientation), so if u flip the case, it will be against what noctua recommends. However I did not notice any difference in performance and temperature.
I will use these fittings and tubes:I’m a newbie to water cooling (besides closed loop AIOs, but do you have a parts list for the fittings and tubes? I’ll be using the LT Solo for the pump block and it’ll be in the 3slot gpu orientation.
www.aquatuning.co.uk
Do I understand correctly, that your tests show that intake is better for CPU temps (or alternatively with same CPU temps lower noise) but worse for case temps?I find that if I run it as intake, with the same cpu temp around 55 c during gaming, fan speed is about 50-60% when using fan as intake and will increase to 70-80% when using as exhaust. Using fan as intake does heat up the case a lot even with a exhaust fan.
I'm running L12S in Ghost but after bending pipes there's no room to make such tests.
I'm just catching up on things with this case - do we know generally what it will cost (Canadian) and if additional runs are coming once things settle down worldwide?
Toronto guy here under lockdown. Once the plague goes away @Wahaha360 will figure it out and let us know.
