So curious about your system! You are the first one to put the 240mm rad in it!![]()
Now the complicated bit, fitting the LT240...
(and I still have to figure out how to fix the rad^^)
What a time to be alive!Well, we are about to be on lockdown... state of alarm has been called, and the PM will appear in half an hour.
Judging by how the frame is designed, I don't think that's possible, that area might be occupied by a radiator.prava said:The second option looks far far better.
But... any chance you could do it occupying only the smaller section?
I’m actually not that into it ? kinda ruins the minimal aesthetic for me. I would prefer if it was completely internal (as an addition to the original front panel, not a replacement), though I’m not convinced there’s space for that. Honestly, what I would prefer more is a single front panel to replace the two pieces, though I think this was asked about before and is in some far future plans.
Thanks for the info, can you explain why the mounting with the SecuFirm 2 is bad?I just finished:
The LT240 was a pain in the ass to refill and the mouting system is crap even with the noctua securfirm, I reused the coils to avoid kinking at the jonction with the radiator. The pump is audible but I guess it's because everything else is dead silent
Flipping the PSU is clearly the way to go, I can hardly imagine how you have to manage the cable + tube + fan in the same little space
I still have no idea on how to fix the radiator (it just sit on top right now), nor of the purpose of the two small piece with two holes in the package
And also I got trolled by the I/O shield of my motherboard, a metal tab is blocking my DP port, I will fix that when I received the button
I just finished:
Technically it is compatible as is, and you should have little to no problems in 2 slot mode, but for 3-slot mode, replacing the tubes is a must because the quick disconnect fitting gets in the way, and makes it basically impossible to route the tubes in the system.Why did you have to change the tubes and refill the LT240? I thought it was compatible as is?
The eisaber have sliding slot instead of proper hole, also the securfirm screw are a bit short so it's difficult to catch them upThanks for the info, can you explain why the mounting with the SecuFirm 2 is bad?
Not compatible with 3 slot mode, the tube are way two long to fit, that's why only 120mm are officially supportedWhy did you have to change the tubes and refill the LT240? I thought it was compatible as is?
I hear it above 1000 rpm, but everything is dead silent around so that must be the reasonDo you have it set to 2000 rpm?
Not ideal I imagine. But does it feel secure when you finished installing it?The eisaber have sliding slot instead of proper hole, also the securfirm screw are a bit short so it's difficult to catch them up
Say no more!
T1 Distro Plate Options
1) Entire Front Panel
2) Only Removable Front Lid
Distro plate source: DICE CASES (hopefully he doesn't mind)
As @Wahaha360 pointed out, due to its size, the first option is more expensive than the second one. Also, by using a distro-plate you'll probably loose support for 2.5” Drives and Front Lid I/O.
Which of the options above look better overall? Don't forget that transparent acrylic glass looks quite different in real life.
Ah I see. Could you share more pictures of this? I'm curious.Not compatible with 3 slot mode, the tube are way two long to fit, that's why only 120mm are officially supported
