    Votes: 116 24.5%
    Votes: 357 75.5%
  • Total voters
    473
fabio
1,885
4,325
No sign from mine o_O
EDIT, from the 11th of February ,from my local post service in Denmark, everything is delayed from China ... I have to forget my case then...
BUT, good news!!! I've downgraded the BIOS of the X570 Strix, and now the temps are so much better!!
Also, tried the Optimus Cooling Foundation in "goofy" orientation, to match my Velocity, and the temp are basically the same.
BUT, even if is a way more restrictive block, the tiny DC-LT have no problem to move water in the loop! Tested putting a flow meter just before the pump, in the most tricky point, and it spins quickly!
Added in the loop also a water temp sensor integrated in the fittings just after the radiator, to check the water temp before going inside the CPU block.
Under full load, CPU+GPU reach the 42 degrees.
End of the week I try the new EK Magnitude!
Wyd4
196
218
Threw my build in the T1 last night. Having all sorts of issues with the memory not allowing it to boot with both sticks in. (It’s been a problem with this setup since I first built it, pops up when I start messing wit cpu coolers etc. either a pin or cpu issue but that’s unrelated to the case).
I feel like everything has been thought of when building this case. It’s solid, everything fits perfect and just the options and mounting, everything just works.
Here are some pics of my build. Please forgive the lack of cable management as I have not put much care into it and haven’t used cable ties as a lot has to come back out of the pc in less than a week to try resolve the aforementioned ram issues and also swap the cpu fan for a noctua.
Wyd4
196
218
really need some custom power cables for this case. The SF600 stock plastic cables are just far too stiff to manipulate in a meaningful way
Brude27
381
878
To be honest USPS is the only worth tracking.
This is one of the only times those words can be used in that order. USPS is tragically bad compared to UPS and Fedex, but when compared to shipping from other countries... No offense to any non-American here, but oof... it's bad. You guys have way better internet and health care than we do, and we have way better tracking. Seriously, I feel like we will get a health care plan in place before getting anything from out of country in the mail sometimes, haha.
chinyang
45
79
Looks like the turning the psu 180 degree is the way to go whether using a aio or not.. will help with both cable management & psu exhaust in this orientation
If turning the psu 90 degree, the cables exiting is too close to mobo, might not be feasible unless using custom ultra short cables
Wyd4
196
218
I definately recommend rotating it 180 degrees. Particularly if you are running the standard cables as I am currently.
theexplainer
90
187
damn, that pinata is cute! :D
for me it's still sitting at "航空公司启运" which seems to mean it's in a plane somewhere, since monday - I guess it's either being delayed because of corona, or at customs
Apheli0n
Hi all, came here from the optimum tech video featuring this case. It's sobering to see that I'm already kinda late to the party, especially with the delays and all... But I'm really looking forward for this case and all the future work of formd! If you ever need testers in Switzerland, count me in! ;)
bynio
70
74
Anyone tested temps with different PSU orientations? My SF600 runs without fan spinning so in theory convection helps, but case fan could do better work.
Wyd4
196
218
hahaha my sons birthday is coming up and the study is a storage room also. Hopefully he has a ball with it
