Is the plan for this case still having the modular back plate for 2-3slot cards?
fabio, tried your HWL LS120 Radiator OC recommendation.
1. Prime95 29.5 Build 9 @ 1 hour
2. 23C ambient temp
3. 9900K OC 4.7ghz, Average CPU Temp < 70 for all 8 cores
*my power consumption seems a little low, so I might test again to verify.
I'm impressed with this radiator. I think Corsair might rebrand HWL LS Series radiators as their new Hyro X custom water cooling parts, so this radiator could be more available.
Thanks for testing, what you said it's probably what I was looking for:
"the Corsair H60 2018 at $40-$70 might be the best for value / performance / compatibility"
The Corsair H60 2018 is a positive surprise.
1. Prime95 29.5 Build 9 @ 50 min
2. 23C ambient temp
3. 9900K NO OC, Average CPU Temp ~ 60 for all 8 cores
I plan to do another test with 2 cores @ 5ghz + 6 cores @ 4ghz. I think 2 core at 5ghz should be enough for most people.
Ooohhh, happy for these results, man!! And the normal wide GTS does even better! BTW, your temps seem to be even better than mine! Let's go on!fabio, tried your HWL LS120 Radiator OC recommendation.
2. 23C ambient temp
When I setup an i9 9900K and let it run @stock speed I have to raise power limit to actually make it run at it's intended stock speeds.
With Power limit set to around 145/160W the CPU runs where it should in terms of clock speed and actual performance.
Your motherboard and i9 might be slightly better than average but still it needs 140W to run freely at 4.7Ghz.
In the OC image you're running 8 cores NOT 16 and then it doesn't use the Turbo speeds given stock by Intel. I'd set up a test where you just have to rise power limits to let the CPU run the stock clocks.
In other words if the config you're testing performs 2080/2050 in Cinebench or Blender renders the BWM in 188/193 sec than it's ok.
Hi, hope I'm not barging into this thread...
Wondering if an AIO like Corsair H100i Pro would fit in here? From the renders on the first post a 240mm rad seems possible to fit, but with only 1x120mm fan.
Or is this case just focused on custom loops that have 240mm radiators?
Thanks!
