    Votes: 117 24.7%
    Votes: 357 75.3%
  • Total voters
    474
jrvd007
45
Congrats to the winners, I look forward to seeing many pictures/build logs.
To whoever gets the Canadian slot, please let us know how much you get dinged by customs.
I second this comment. I would really appreciate if johannbl could tell us how much the customs hit for once they get the package :)
Kuzan
58
70
Congrats to each tester, looking forward to see all the T1 builds :)
btw @Wahaha360 have you considered teaming up with Noctua (or another brand) to bring out an optimized air cooler for the T1 e.g. like the black ridge for the A4 and the upcoming noctua cooler for the ghost s1? Or do you think there is no need since there is already a good option with the l12s and next generation cpus prob will have same/less tdp with higher performance?
Navic
587
1,341
I think instead of an air cooler, he's trying to make his own radiator for a liquid cooled setup, and IIRC, he has a prototype pump/block combo thing for it as well
Reactions: PBJ
Wahaha360
a.k.a W360
2,131
10,697
USA
The Ghost S1 Noctua Cooler is either the old L12 at 68mm tall to fit better or Scythe Big Shuriken 3 alternative, and there 3 problems:
1. unlikely to cool better than the L12S at 70mm
2. likely cost more
3. potentially less RAM clearance
4. potentially the fan will be next to the side panel = worse noise than L12S
So I ask this, what is the point.
I might offer a Black L12S later depending on what Noctua wants, but my priority is maybe AIO using Noctua fans. L12S with black paint doesn't move the needle compare to L12S.
Next gen CPUs are more power hungry, air cooling is kinda f**ked for SFF under 10L. It's both physics and dimensions, you are not going to get much more air cooler height for cases less than 10L, at <= 70mm limit, your cooling potential is not going to get much better than L12S.
This is why I asked the higher powers for a new Mini-ITX motherboard. The RAM Slots + VRMs will limit SFF air coolers.
Psyduck91
69
62
When I did my test run with my new parts, I noticed the default 24 pin cable that came with the EVGA 550 GM is rather stiff so I'm a little worried how well I can cable manage it having never built in a SFF before. Would I need to invest in some sleeved cables?
Also I'm really glad there's progress made towards shipping these cases out. I'm very impressed with what you've been able to accomplish @Wahaha360 . I'm looking forward to what you have planned for the vertical case.
Wahaha360
a.k.a W360
2,131
10,697
USA
T1 has a lot more spacing between SFX and motherboard than the other indie cases on the forum for the 24PIN and hard tubing, so you should be fine.
h4ndcuffed
US - Other is not part of the Test Shipping, I made exception for members that have been active on this thread for a while.
Totally get it! Just sad I wasn't here or active... lol. Nothing on you or the community, that's on me and it just means I wait a little longer, that's all haha.
gteixeira
23
Since the T1 is geared towards being friendly to travel and to watercool in,
Is there a a thread explaining the etiquette of travelling with a custom loop / 240mm AIO / 120mm AIO sff build through airport security?
Surely the liquid volume exceeds the total amount allowed in the plane, right?
gwertheim
938
1,555
There are reddit posts about it but I would check your local government's website
Reactions: gteixeira
Wahaha360
a.k.a W360
2,131
10,697
USA
In the US, TSA PreCheck = less hassle.
For other country airports, just tell them the AIO is sealed.
itsmichael
43
42
Austria
Oh wow, I just checked this thread again and to my suprise I was one of the lucky ones :).
Looks like I have to buy some new parts now,I haven't be so excited for quite a bit.
Congrats man, could you share the infos (shipping time, cost, etc etc.) for austria with me when you've recieved the package? i was one of the other two contestants :)
@Wahaha360 btw: why is optimum tech calling the case sidearm and not sidearmd, as you've answered someone a while ago? have you talked to him about that? ?
