    Votes: 116 24.5%
    Votes: 357 75.5%
  • Total voters
    473
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Would xspc tx rad whic is Dimensions: 125 x 20.5 x 278mm (WXDxH) +-0.5mm be option
Worse performance than LT240.
If you run slim 15mm fans between the panel and XSPC TX240, it will fit.
It will not fit if you try to put the radiator next to the panel.
Brude27
381
878
Like I said, I am literally sitting on the couch watching Narcos Mexico season 2. I ain't doing shit. @Wahaha360 is the one still wearing pants doing all the work.
:D
Well, it’s much appreciated nonetheless. :)
Also, Narcos is so good! The last season is the weakest, but the first 2 are fantastic!
Navic
587
1,341
i meant if it's possible to install 2.5'' Drives at the bottom or top depend on case orientation , and 1 more in the front of the case .
No, the only spot for a 2.5" SSD is at the front of the case unless you want to get some double sided tape and mount it yourself
Mahjund
23
i think with a bracket ppl will able to choose whether they want to install Fans or 2.5'' Drives , i hope this will be in the future batches or a separate bracket that we can buy Via Sidearmd T1 website , More Flexibility is always a good thing .
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Since the size of the quick release connector seems to be the only issue for the second config, do you think using low profile/no heatsink RAM will give enough clearance? Trident Z = 44mm, without heatsink = 31mm. And maybe with thinner, custom PSU cables as well.
I don't have low profile ram. I will try and find some Corsair LPX to test.
Reactions: heckinwoofer
fpdhs0610
Will this case would able to fit DMX motherboard in? Like Asus Crosshair VIII Impact. The motherboard is big longer than average mini itx motherboard.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
What is going to be the size of the first batch? Would it be limited only to the test shipping list?
First batch 150 pcs, 50 pcs missing mesh side panel ?
Spoke with factory, they will make sure we have enough starting April.
The bigger problem is my warehouse is closed and I don’t know when it will open.
alberto.vgdd
First batch 150, spoke with factory, they will make sure we have enough starting April.
Okay, I will cross my fingers and wait for that first batch to be ready and check if I can get my hands on one. If it was a more limited number I would look for some other (uglier) case to build a PC in.
Shinken1
90
95
My mistake, mini-dtx will not fit.
Radiator Box / Top Hat for the T1 allows it to support 30mm thick 240 AIOs, I’m on the fence.
Very interesting, I'm imagining the front of the case being in 3 sections now, or perhaps 1 of the 2 current front panel sections will be longer?
Could make the case appeal to those that want to throw their current 240 AIO into the case but I thought your other new case would cover that?
Look forward to seeing renders if you decide to go down the Radiator Box route.
njames1022
Update 2020-02-18 : 240 AIO questions will not end ?‍♂️, ONLY ONE 240 AIO FITS - Alpahcool LT240, but 240 AIO is not officially supported!
Update 2020-02-18 : Accidents or foul play, some candidates' entry for was deleted. So we are extending TEST Shipping Campaign to Sunday, 2020-02-23 12:00 PST (UTC-8), use this Google Form to input, everyone who entered last time, please re-enter again using this form
Update 2020-02-07 : 240AIO ppl, I made a new thread just for you[/SIZE]
There is just too much congestion on this thread around 240AIO support. The LT240 will still work with T1, but for *common AIO support, a new thread
Update 2020-02-06 : Preorder on hold until virus situation settles in China.
Three reasons:
1. the virus has created a huge backlog and uncertainty for shipping, I don't want to take orders with this much uncertainty around shipping.
2. I have requested more T1s to be made, so delay preorders = the gap between availability will be days / weeks instead months.
3. more T1 availability = less anger and fighting on the forum, less disappointment.
Update 2020-02-04 : OptimumTech review video dropped - 9900K on 120 AIO can out perform 240 AIO, 240 AIO is really for the obsessed.
Update 2020-01-30 : OptimumTech video drops February 4th PST. We can't ship and must evacuate due to coronavirus outbreak in China (so we will not take orders) ?‍♂️.
We have been notify to evacuate out of the country due to the unknowns surrounding the coronavirus outbreak. Warehouses and logistics companies are also required to do some sterilization (kill germs is the exact translation) during February. Unforuntately, this pushes the earliest possible shipping date to March 6th.
I know this sucks, but we can't control a virus outbreak, so it's FML situation on our end too.
So many ideas, so little time
T1 Black + Mesh Side Panels Availability: sidearmd.com, preorder after OptimumTech video, shipping date target 2020-Feb-15
T1 Black + Mesh Side Panels Price: USD 200, excluding shipping (Free to USD60 depending on shipping speed and country)
T1 Black + Mesh Side Panels Specifications:
Material:
CNC machined from 15mm 6061 Aluminum + 1.5mm steel SFX and Fan brackets
Side panels: ultra-fine mesh side panels (also functions as dust filters)
Colors: Sand Blasted + Anodized Black Aluminum chassis, Powder Coated PSU and Fan brackets.
Dimensions (W x H x D): 133 x 216 x 330, 9.48L
Graphic cards support: 312mm long, 2 or 3 Slot GPU (39.2 or 59.2mm from Side Panel to GPU PCB, including 1.6mm GPU PCB)
Motherboard support: Mini-ITX
Power Supply support: SFX
CPU Heatsink support: 70mm height (Noctua L12S recommended) using 2 Slot GPU or 50mm height using 3 slot GPU
Water cooling support: 120mm AIO at 35mm thick
Drives: 1 x 2.5" HDD/SSD
PCIe Riser: Included
I can’t wait to get my hands on this case.
Proflucifer
92
42
I don't want to make many seperate posts, so.
1. How much does the case cost?
2. Will WeChat pay be supported?
3. Is shipping included in the cost?
4. What I spired you to make your own case and how did you learn how to design be cases?
5. Is this your full time job or a side gig?
Navic
587
1,341
I can answer some of those (also check the first post it will answer a lot of your questions)
1. $200
3. No, shipping is separate
