Thanks, unfortunately it appears there’s no option for “USA-Other” this time around. Does that mean I don’t qualify as an option?
Yeah sorry
I understand. You guys must have your reasons for the change.Yeah sorry
rather than making hole in the table, u can just swap to higher casing leg or just use case stand (if u lucky, u can find case stand that came with fan or u can just mod the case stand and fit it with noctua fan on it)Yeah for the same reason I'm thinking about making some kind of vents/holes in my table![]()
I was just thinking about 3d printing feet that could fit into the grill holes.rather than making hole in the table, u can just swap to higher casing leg or just use case stand (if u lucky, u can find case stand that came with fan or u can just mod the case stand and fit it with noctua fan on it)
Went a bit crazy after Wahaha announced test shipping lolDamn, is anyone else having trouble keeping up with the thread? There's like 10-15 new pages everytime I check back.
I'd like to run an air cooled build. What would be the best case fan config?
@Wahaha360 lt240 arrived today, do you need me to leave it unopened in box?
Unfortunate situation with the changes in the spreadsheet..
In this new form, will the # of posts actually not matter unless you have over 50 when you are picking the candidates or will you check them all individually? @gwertheim @Wahaha360
I just wanted to remind people that this type of watercooling is pretty difficult to build, but mainly to maintain. Eisbaer LT pump is not really powerful making all draining/filling operation complicated/nightmare.
Personnally I'm interested in aircooling version..
Stupid question, is it possible to get taller feet? Provided feet are too short to get good cooling, intake or exhaust.
Sliger SM550/560 cases remain benchmark for GPU cooling with their tall feet and vents..![]()
Yeah one of the concepts I was theorycrafting with friends is having connectors to something like https://koolance.com/radiator-9-fan-120mm-18-fpi-aluminum or a radiator from a truck/Opel Vectra at home with a ceiling fan going 5RPM cooling it and then something smaller to go when travelling or having a lan party, but I'm not there yet mentally to accept it as a viable solution (getting there thoughIt's your table and you can make as many holes as you want. May I recommend a nice sized one for a tube which leads to an external cooler/pump.
