    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
JonnoWasTaken
2021-08-28: T1 V1.5 Update:​
Waiting for anodizing on the prototype. Will reach out to Beta Testers once I finished testing.
These renders look great, I nearly pulled the trigger on an Ncase M1 for my first SFF build but the reference layout has caught my attention, might have to hold off until I can get my hands on one of these.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
This is interesting! I like it!
Does this mean there will be no more rear mounted power button?
Is it also possible to switch the position of the power button and type-c header so they can be on either side of the case?
Or is this one of the optional accessories? Really looking like customization with this version is going to be crazy.
You can *still mount rear Vandal Power Switch if you choose to.
New version adds USB-C Front I/O mounting and USB-C Power Button to the side of the Front Panel. And yes, location swappable.
DavidN
27
Damn those 1.5 renders look sweeeeet. Been waiting since last November and even had my other components on the shelf since then. Guess I can wait a little longer (but please, please, not too long)... :)
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Will the HWL 280GTS radiator support allow a second TX240 radiator? Or will the configuration only allow the single 280GTS?
The radiator will fit, the problem is the fans.
For dual radiator setup, you will need two slim fans on *one of the radiator touching the Mesh Side Panel, where the TX240 with two thick 25mm fans will be next to the Top/Bottom Panel. You can’t get slim 140mm with 140mm fan mounting afaik - that’s the real challenge.
SoSquidTaste
138
213
Oh, fascinating! Do you have any experience with those Noctua 120-to-140mm fan adapters? I'm happy to try test fitting the 280 GTS I have on hand + 2x NF-A12x15 + 140 adapter on the side and compare it with the spare TX240 also on the shelf right now. Even got a couple of those Kaze 12mm fans on hand that could go in the mix! Just in case beta test batch hasn't been finalized yet
Reactions: Kapsi
DrHudacris
918
1,720
I'd be curious how these work with slim fans. Wouldn't the "pegs" need to be trimmed down as well to match the fans being attached?
SoSquidTaste
138
213
That's precisely what I'm envisioning, too. TBH I haven't worked with them before but it looks like they're just structural elements. And we're certainly no strangers to filing down superfluous bits of Noctua plastic here in this thread, right :p
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
3D print the fan adapter.
D
Deleted member 24274
Guest
If I choose to install the rear anti-riot power switch, the front USB-C power button will be useless
Navic
587
1,341
You can use it as a reset switch. I have two buttons on the back of my T1, one for power (which is the premium button I bought after I got the case) and then the stock button that came with the case is a reset button. Comes in handy every once in a while.
Plus, if you put your case near a wall like I do, you won't be able to realistically use one of the sides of the case, so that's the side I would put the reset switch on, so I can have easy access to the type-c header. This is my current plan for when I get a v1.5 (Have a power button at the back, type-c header facing me, and then reset button on the other side)
Or, you can theoretically wire both buttons to the power button header on your motherboard, so either one of them can turn it on.
Reactions: AlexTSG
D
Guest
I like the minimalist style. The reset button is redundant for me, but I will consider your plan. After all, this is more reasonable.
