Just to clarify, does 49mm include CPU+CPU socket or is it just the maximum CPU cooler height?
CPU cooler height is 49mm, excluding socket height.
In regards to the one piece front frame, will we still have the option to have mix and match colors to get that minimalist looking two tone (such as how it is now) and with the GPU support increasing does this increase the overall length of the case or are the panels simply thinner?- 1mm depth increase, 133x217x331mm
- one piece Front Frame for better color control and match with Top/Bottom Panels
- recessed Front Frame canvas for two-tone and other creative possibilities
- 1.25, 1.5, 1.75, 2, 2.25, 2.5, 2.75 and 3 GPU Slot space allocation on *single Rear IO Plate for finessed GPU space optimization on less parts
- dual 240 radiator / AIO cooler support on 1.25 GPU Slot with *single slot WC GPU.
- vertical stand upgrade kit for less desktop foot print
- recess cutouts for magnets, for holding Mesh Side Panel or Tempered Glass Side Panel in place during disassembly
- support for 320mm long GPU like ROG Nvidia 30XX and AMD 6XXX (MSI Gaming X Trio and Suprim X not supported, 5mm too long)
A bit longer gpu support, now the spine can be moved to more positions, so we can put a 240mm rad on the side appart form the one on the top. Also vertical stand
Hi Wahaha,![]()
Nothing is final until it’s final. So here are some updates to give you guys idea what’s on the list for V1.2:
I guess the two tone will be possible, but I´m just guessing, to know exactly how is it going to be we will have to wait a bit. I just quoted wahaha in case you didn´t read that post. That´s all the info I have, no more no less.In regards to the one piece front frame, will we still have the option to have mix and match colors to get that minimalist looking two tone (such as how it is now) and with the GPU support increasing does this increase the overall length of the case or are the panels simply thinner?
The front T frame limited GPU length in the current version. With one piece frame, I guess they solved that issue.In regards to the one piece front frame, will we still have the option to have mix and match colors to get that minimalist looking two tone (such as how it is now) and with the GPU support increasing does this increase the overall length of the case or are the panels simply thinner?
Can i got one slot to @Wahaha360 ?![]()
I understand that haha, but you never stop amaze meIIRC, you already have one right?
The bigger problem is allowing priority to those who already have one will create internet rage, just trying to avoid drama.
With the rotary terminal in 1.25-slot mode, one of the fittings will be pointing to the rear of the case. It seems that there is no exit path for the tube, or am I missing something? There is only ~6mm between the side panel and a typical waterblock, so I don’t think one can squeeze a tube in between.The clearance for CPU + Block is almost 49mm. If the Side Rad / AIO Fan Bracket can allow movement towards and away from the Top/Bottom Panel, we can make clearance for taller fittings.
Yes, terminal rotary fitting for the GPU is a must for dual 240 setup.
Might have to rely blocks with the ports at the rear of the card; I don't see any other way of achieving it. Even then, those blocks tend to be thicker than usual.
Plus, what pump can you fit in the remaining space that can support 2 radiators?
Have you looked at adding support for Flex PSUs? maybe that could open up some options.
Thanks. Looks like one rotary 90-degree fitting plus one non-rotary 90 may work, depending on the height of the GPU rotary terminal.Good observation, you will need to 180 degree fitting so both tubes point towards the front of the case.
Again, this is for people trying to squeeze dual 240 rad in a <10L case, not a whole lot of space for other options.
