Oh interesting, thanks. Hopefully someone else can chime in soon.Yeah I think so, but don't know if you gain anything doing it vs two fans underneath, push is said to be better than pull.
Would be nice to see a comparison between the two setups
Is the Strix thing happening?
Anyone know???? my Strix arrives this week... and my case will be shipping mid January...
I haven't tried this myself but OT said in his video that you can uninstall graphics drivers prior to updating BIOS.Sorry if this has been covered.
What's the consensus on PCIE 4.0 capable risers? I know the 3m one is supposed to have the bandwidth, but does it actually handshake as pcie 4.0?
I'd really rather not have to take the 3090 out and replace it with my old PCIE 3.0 card every time I clear CMOS....![]()
Will existing case & strix owners get first dibs?Yes, but it will require a new Front T-Frame that's going to release closer to Feb 2021.
So the 3M riser works as PCIE 4.0? I assume this has been tested?
Where can one buy one for the T1?
While we're on the topic, anyone know how well the louqe 4.0 riser works? It's on preorder on amazon rn so i'd like to get in on that if it works well.
apparently the linkup riser isn't so great but i'd rather not buy one now and have to replace it later when risers are better.
if we had a ranking of 3m louqe and linkup that would be cool.
edit: or i guess i could just deal with the 3.0 quirkyness until risers are worth it lol. thats probably the better option.
None of these risers are cheap, if you going to spend the money, why not stick to 3M when you know it just works.
Check out this Legend’s detailed post on reddit (check the graph way down the bottom). I think adding the noctua A12x25 underneath makes a pretty significant difference. In Matt’s testing he targeted a 31C water temp with 20C ambient. With just 2 slim fans he had to run them at 1300RPM, with an extra noctua 25mm he could run them at 950RPM instead. Guesstimating I reckon that’s a 2-5C different in water temps when running at the same RPM. The A12x25 is just such a beast. Keep in mind his slim testing was done in pull, so you *might* get 1C gains on push.Oh interesting, thanks. Hopefully someone else can chime in soon.![]()
I have not been able to find a 3M cable with the reverse connector for the GPU side.None of these risers are cheap, if you going to spend the money, why not stick to 3M when you know it just works.
