    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Mac2636
47
Either one of these better than the other for the Sidearm T1? Knowing the fans will need to be replaced, is the rad & pump worth considering?
EVGA CLC 280mm cpu cooler for $80 and EVGA CLC 360mm for $100 or less
pwnedundies
199
356
Nope! At the moment only 120mm aio are officially supported. There is only one 240mm aio that will fit and it requires some modifications.
mtacx
will this case support Aorus geforce rtx 2080 Ti Xtreme waterforce with pre installed waterblock and EVGA GEFORCE RTX 2080 Ti FTW3 Hhydro cooper gaming (the one that have preinstalled waterblock)?. im planning to buy one of those card for sidearm build.
FunkEngine
46
40
Is... is this bait?
Mac2636
47
He's asking if you had read the first post
I did, but missed the details about which aio would fit. Since I have really only been considering air cooling for the cpu up to this point. Saw the deal on SD and it triggered my interest. Sorry for the dumb question.
Mac2636
47
Now I'm even more confused. Went back to reread the 1st post and see the quote below.
"Update 2019-01-07 : 240 AIO support and no size increase (working it out with OEM), details on this post."
But I'm still missing where the exact 240 aio description is. I see the Eisbaer in the pic, but not finding the text. Sorry if it's in plane sight and I'm just missing it. Trying to look on my phone.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
The latest post may not be loading for you.
Officially supporting 120AIO where the radiator is less than or equal to 30mm thick.
240mm AIO is not supported.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Ok. Thanks. But 240 was being considered at one time with 1 normal and 1 thin fan?
Oh and thanks for being patient and answering all of my ignorant questions. Really appreciate it.
240 radiator that’s 120mm wide and 25mm thick or less will work in the case with a thick fan + a slim fan.
The real problem with 240 AIO is the tubing length, which requires modification, that’s basically a custom loop. For this reason, we dropped the official support for 240 AIO.
Reactions: Goatee
Mac2636
47
M
Makes perfect sense now. Thank you.
