FormD T1 - 9.5L with UNLIMITED space!! - 3950X+64GB Ram+2GPUs - TITAN V FULL watercooled+TITAN RTX!! Fill the void 2.0
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
3,103
4,592
46
France
guilleacoustic.wordpress.com
I think that you will not succeed by many criteria. Start thinking about cooling and don't bother people with all sorts of rubbish.
These cards have different memory bits -
don't lie to people
Your words are cheap show-offs
Sir, I have no hatred for anyone. Wrote the truth
First and last warning @sancho. You can disagree and be civil at the same time.
Criticism for the sake of it won't lead anywhere. Nobody's growing from it, you included.
LCK sb
28
香港
I just received pcie's stuff from Germany today, and found that there is no module that accepts the graphics card. If you have one, I will ask you.
fabio
1,885
4,325
I would like to help, but I don’t understand what are you asking for. Could you explain maybe with some pictures?
LCK sb
28
香港
psc
fabio
1,885
4,325
No problem!
But as I told you before, I prefer not to dive it around.
The designer of the bifurcation riser gave to me the original to reverse engineering it to adapt to this case.
To thanks him, I gave it to him so se can provide it with his riser.
sorry!
paulesko
415
322
Hi @fabio one simple question:
Are you having problems with the noctua thick fan turning on and off? Neither of my noctuas turn on and off reliably with this gigabyte motherboard... sometimes they work sometimes not. But this problem only happens when I use PWM in bios to command them, they work well with normal voltage regulation, although the minimum turn on rpm when working with voltage is 850 rpm and not 450...
If yours work, maybe is a thing that the chromax version has fixed, mine are brownish and there are more people out there with the same problem and gigabyte motherboards... but I haven´t read why or if there is a solution.
fabio
1,885
4,325
Try first to do an automatic Smart Fan Setup, so the system will check the minimum speed. Than in the BIOS Smart Fan menu there is an option to disable the 0rpm/Not allow to have off the speed, something like "Auto Fan Stop"
Reactions: paulesko
paulesko
415
322
I haven´t tried that one, I remember seeing it on the bios. Thank you!
Reactions: fabio
LCK sb
28
香港
No problem!
sorry!
I want the size of this little thing, I can't find anything fixed now
fabio
1,885
4,325
There is another one, just want to ask whether pcie 4.0 will improve this dual graphics card
If you are using 2 Gen4 cards (like the AMD 5X00/XT series) and a compatible Gen4 riser, IN THEORY, YES.
In real world scenario, it almost not noticeable the difference! (There a few good articles on this)
For the drawings, sorry, no, I can't.
LCK sb
28
香港
I found a way, it doesn't matter, you introduced me a good idea
Reactions: fabio
LCK sb
28
香港
Does this adapter currently only support Gen3 adapters?
