UPDATE : build finished
Some pictures : http://s305.photobucket.com/user/hagoun/library/Streacom FC7
Hi there,
As my title does suggest, my project is to fit a full size GTX 750 Ti into a Streacom F7C.
- Mobo : MSI B150I GAMING PRO AC
- RAM : Crucial DDR4 2 x 4 PC4-17000 CL15
- CPU : i3 6100
- Heatsink : Noctua NH-L9i
- GPU : Gigabyte GTX 750 Ti + Zalman VF900-Cu
- PSU : HDPLEX 250W
As low profile single slot GTX 750 Ti do not exist, using a PCIe riser is mandatory.
This is ribbon I will use for my project : Liheat Type A.
My initial idea was to use MSI's 750 Ti Low profile.
However, the Liheat riser being unpowered, it can only feed a 30W TDP GPU.
I may have given the 750 Ti LP a shot (since TDP is limited to 38.5W into the bios) but I am pretty sure it wouldn't have worked out so well.
Hence, I returned the 750 Ti LP and purchased a Gigabyte 750 Ti instead, which is the most compact 6Pin-equiped GTX 750 Ti.
The GPU itself indeed is pretty compact.
Enclosed some pictures of the current 3D study of my build :
As you can see, I chose to replace the original heatsink by a Zalman VF-900CU I had laying around.
I know from Overclock.net that it will fit.
Everything was looking good in my first drawings.
However, after having updated today the Liheat riser model with real values (thanks iFreilicht), even with a reduced heatsink and a compact GPU, it is going to be a very tight fit...
There is no more than 1 mm clearance between the GPU cooler and the top of the DDR4 DIMM modules.
Hence my first question :
Is it a good idea to replace the current DDR4 memory by DDR3 memory very low profile, like Crucial CL9 Ballistix Sport VLP (and buy a cheap H110 mono supporting DDR3) ?
I am pretty sure my GPU will fit but I give up on DDR4...
Hi there,
- CPU : i3 6100
- PSU : HDPLEX 250W
