News EKWB VTX pumps
EK just released VTX pumps with slightly better specs than the DDC pumps but same footprint.
A lot of projects here are designing around DDC pumps so I thought about sharing this. What are your thoughts?
fabio
1,885
4,325
That's not a bad result for a loop with quite a few 90' fittings and a disconnect coupler!
Exactly!! Of course the VTX head pressure is the one that removed the air in the loop quite fast!! But Was nice to discover how the flow is indeed important, but a DC-LT at 100% does its job!
Of course the reliability is not the same, that's why I prefer to stay with the VTX/D5. Especially because in my setup I have a dead space that fits perfectly the external combo.
Here some comparison pictures. I will do more later with an SPC and DDC as well.
The sleeving though is different from their D5 TBE Kinetic (left) where it's pretty nice and I think is Paracord, while the VTX has the classic nylon sleeving.
fabio
1,885
4,325
So, I've measure and written down some info regarding the VTX:
100% (4950rpm)
43dB - >200 l/h flow - 44 degrees
80%
43dB - 190 l/h flow
60%
39dB - 155 l/h flow
40%
34dB - 120 l/h flow - 37 degrees
20%
32dB - 90 l/h flow
12%
30dB - 85 l/h flow
Here you can kinda evaluate the noise. The main problem is this "splash" sound. I don't know what can be, it get lower on slower speed like 20/30%, but it's very annoying.
I think we have to wait for other reviews. Maybe mine have some issue?
VTX 50 to 20% 1/2 Video
VTX 20 to 50% 2/2 Video
@pwnedundies
duynguyenle
331
331
100% (4950rpm)
80%
43dB - 190 l/h flow
60%
39dB - 155 l/h flow
40%
20%
32dB - 90 l/h flow
12%
30dB - 85 l/h flow
@pwnedundies
Rattle might be indicative of a slightly out of balance rotor, but it's hard to tell
duynguyenle
331
331
Depends on what the issue actually is. If it's coil whine you could slather the mosfets in a little bit of putty or epoxy. If it's an out of balance rotor it's not really easy to fix (it involves sanding/grinding or otherwise taking material away from the rotor assemblies where the imbalance is (or add small balancing weights 180 degrees out of phase of the imbalance), at least that's the SOP in the gas turbine world, I don't think either solution is really applicable here. Probably just contact EK and see if they can replace it for you.
fabio
1,885
4,325
Yep, I did, let's see what they will answer!
Reactions: pwnedundies
Vacceo
76
49
Thank you a ton, Fabio, for letting us know. Now, time to lobby EK to get the pump spare and for other reservoirs... :D
Protools
69
42
I really like how you made your setup there with the dampening feet(?) for the pumps and all.
Plus you're the lucky winner of Sidearm T1!
Reactions: fabio
pwnedundies
199
356
Somehow I didn't see the last post you linked me in. I'm super interested in this. That noise is interesting and not pleasant. If it doesn't stop I wouldn't see a need to switch from the dc-lt ultra. Looking forward to the update. I'd like to find a way to put this in my sm580. I'm possibly going to take out a 140mm fan and put it in one of the 120mm flat reservoirs.
Reactions: fabio
fabio
1,885
4,325
I've asked to RMA it, I really want to see where the problem is!
dfsaqwe
THAT is an amazing setup.
I know! If you open the link in every pictured there is the Ambient Temp, (26 degrees Average) Coolant temp, ecc. I'll post it here also.
The Pumps were external for an easy swap.
About the exact setup:
AMD 3950X
Titan RTX
EKWB Vector RTX GPU Block
EKWB Magnitude CPU Block
EKWB 240 Classic SE
AquaComputer mps 200 Flow Meter
x5 EKWB 90 degrees Torque Fittings
x1 EKWB 45 degrees Torque Fittings
x6 EKWB Torque 10/16 fittings
x2 Sets Quick Disconnect Koolance QD3
EKWB 10/16 ZMT Tubing
D5
DC-LT
VTX (DDC)
fabio
1,885
4,325
Received the second unit from EKWB!!
No sound problem, and here you can evaluate by yourself the sound/noise! The distance from the pump is always more or less 20cm.
You can see me lift a bit it to avoid some noise from the vibration on the desk.
At higher speed it gives a bit of "splash" sound, but as you can see at 60% the flow is incredible!
In Idle the total sound level at 30cm is 29/30db because of the slim fan at 1000rpm.
What do you think?
pwnedundies
199
356
Thanks for the follow up @fabio.
I'm glad you recommended the ek 3.1. I have it set to stay at 20% speed at all times and it's got so much more power than the dc-lt. I can imagine the vtx is awesome but probably just unnecessary for now
  • Love
Reactions: fabio
fabio
1,885
4,325
It is! I was trying too look if anything similar exist, but the only one is the DDC 1T Plus PMW that it's 18W (WHY!!!!???)
Legion
364
402
I've read recently that Alphacool DC-LT V2.0 may be coming, they are testing them atm in their prototype units for the new line up of Gfx card water cooling solutions.
Fast forward it to 3:25 to see the prototype.
VTX is good, 200 euro for that unit is somewhat excessive though. Why the heck don't they sell the pump on it's own with a lineup of tops *grr*
A VTX pump with a DDC 1U micro res would be the ideal solution here for getting some pump power into small cases.
I emailed EK about selling the pump seperate and if it is physically compatible with DDC tops and other products designed for DDC
If it is, that's what I plan to roll with.
fabio
1,885
4,325
This DC-LT V2 IMO will be not exciting. I think is the one in the Aurora Eisbaer though.
They say that now is a 6-pole one, but with a lower max flow (75l/h vs 100l/h, with head pressure of 0.98m - they say it's 10% more powerful though) and still DC voltage controlled and not PMW.
Here the Eisbaer Aurora detaield specs:
