eGPU w/ Plex ???
Germanese
80
84
Well I had a thought.
Could i power a eGPU with a plex ?
This way i can keep the set up very small in a custom Box ???
KMPKT
3,382
5,935
By Plex do you mean HDPlex? If so, then yes you can. The Dynamo I'm designing is actually meant to do exactly that.
TinyAudio
188
132
KMPKT
3,382
5,935
Then yeah you should be able to do that with my unit once I release it (it's an HDPlex made product). You'll still need to get a TB3 to PCIe adapter though.
Germanese
80
84
so taken the case/housing out of the equation.
I can do GPU PCie to TB3 USBC conversion and add HDplex PSU. that will make it fairly compact
