If you're looking for a small and convenient eGPU, you can pick up an Aorus Gaming Box RX580 from eBay and replace it with a short <200mm GPU. I picked up an ASUS DUAL RTX3060Ti O8G MINI V2
However, you may need to do a voltage mod. Some brands of GPU's won't power on the eGPU enclosure properly (like ASUS). To bypass this and always keep the GPU you need to solder the following wire:
This keeps the eGPU enclosure on all the time but at least it works. Without the mode the ASUS card would not get detected in the eGPU box.
