Ebony Cube
wesbl
174
115
Small preview of my cable management
Reactions: K888D
wesbl
174
115
4 Hours of Prime95, 65°C, not bad, right?
Aida64 again:
What's the right temperature of my CPU? 41.5°C or 46.5°?
Reactions: K888D
MarcParis
Apr 1, 2016
3,597
2,676
Look tº die/tcl on hwinfo64..:) 46.5ºc thus..:)
Nice temp fo 65 on prime.
Aida is far less restrictive as you don’t check fpu..;)
wesbl
174
115
Yes, I wanted to try something more realistic with Aida 64 and something absurd with Prime95.
So I can say that the temperatures are almost like my open air tests.
Idle:
wesbl
174
115
Nice temps definitely..:)
Hwinfo64 should show also fan rpm..;)
Fan control? I've used SpeedFan manually for run fans at 100%, because on bios there was the stock curve, I have to change it.
wesbl
174
115
Build Photos (Updated first post with build pics): https://pcpartpicker.com/b/zs8Ycf
Tried Fumark after 100% Fan, I have fps locked at 60fps, I have to figure out why (I think xbox app) , It's the first Nvidia Gpu after almost 3 years:
EDIT
Find out fps lock issue: disable xbox gamebar.
Even better, nice boost clock, lower temperature:
EDIT 27/10/2017:
Tried Prime95 after almost one week, 4°C lower, medium 2/3°C. Thermal paste "curing" takes effect?
Prime95 + Furmark!
Pc case stay really fresh also stressing both gpu and cpu, the only part warm is the gpu side.
Like TekEverything said, this gpu push a lot of air on case front hole
Reactions: K888D
