Desktop DAC + USB hub to replace front panel (?)
batterybull
43
Does such a thing exist?
Would be nice to not have to worry about front panel audio and usb when working with a custom (scratch) build and just have a power button. Most commercially available front panel assemblies look pretty bad especially when put in a custom case.
Germanese
80
84
I think he wants the DAC to have some USB ports.
I have only came across 1 so far 3.5mm DAC but it was inferior and it is discontinued i think.
GuilleAcoustic
Chief Procrastination Officer
LOSIAS
Jun 29, 2015
3,103
4,592
46
France
guilleacoustic.wordpress.com
XD I guess I really didn't get what (s)he wants. I thought it was an alternative to after market front audio + USB PCBs, hence why I suggested using a motherboard USB header to connector a USB DAC PCB and a USB hub PCB.
Well, if it is power button only and use desktop DAC + USB hub to provide what's missing .... I do that on a daily basis XD
Germanese
80
84
If you wanna talk to Burson Amp they are on a new rotation on new version for 2019.
They are very open to suggestions, on improving their 5.25" Version Audio Play.
I myself am looking for a 3.5" Dac Amp with OP Amp Swap ability
batterybull
43
Yeah maybe I wasn't clear, I'm looking for one hub that replaces the front panel with usb and audio but all I could find are separate units.
USB hubs also pretty much only have one usb input (connecting to the pc) which is suboptimal performance wise compared to a front panel that connects directly to the internal motherboard usb header.
Edit: Just to be clear, I meant as a separate desktop hub instead of integrated into the case
