Enclosure DeskMeet Chassis
Analogue Blacksheep
850
706
I guess for others trying this in the future with the S4M, I could see there is an option to use an ITX or Low Profile GPU and see if you can fit the HDPLEX 500W unit.
I can see @riba2233 forthcoming U-ITX case being a good fit for the this board. You could use a much more powerful GPU and have the 500W unit fit perfectly. You would still need to figure out the cables.
Reactions: riba2233
vinnyoflegend
158
102
Can’t believe I missed this discussion. I wish they would sell just the Deskmeet boards separately without the other parts.
I’ve been wanting to put one “in” though maybe “on” 😉 is more accurate with the XWorks X32. It would only get slightly past the ITX edge and line up closer to a 200-220mm GPU. The front IO just becomes a bonus.
