DAN C4-SFX
Boil
1,253
1,094
...your statement of "So you want a slower interface, a larger physical drive, and two extra cables in your system; all for twice the capacity & a 33% price drop...? Pass..." is totally wrong.
But if it is MY statement, pertaining to MY world view on SFF storage, it can inherently only be correct...! ;^p
The year is 2037 and a M.2 NVMe SSD on PCIe Gen69 has 420PB of storage for the low cost of only 27 Simoleons...!
Bonusround
220
243
Again: U.2 is the best of both worlds. The physical area of 2.5” (greater capacity at lower costs) + the speed of NVME + the flexible placement (and improved thermals) of external drives.
The solution exists. Pity it’s only widely adopted in the enterprise.
Reactions: Revenant
Boil
1,253
1,094
Six Slimline PCIe 4.0 x8 for U.2 connections on that Epyc Deep ITX mobo...?
I envision a C4-SFX XL, about 20mm or so wider, with the additional width behind the mobo tray & mount locations for six 2.5" U.2 NVMe PCIe Gen4 SSDs...!
Add the 10mm or so height to allow for 25mm thick intake (normal mode) / exhaust (inverted mode) fans, should still be 15L...!
64-core / 128-thread Epyc CPU
Up to 1TB RAM
4TB M.2 NVMe PCIe Gen4 x4 Sabrent Rocket Q4 SSD
Six 2.5" U.2 NVMe PCIe Gen4 x8 SSDs (nearly triple digit TBs total?)
Radeon Pro W6900 (80CU / 32GB GDDR6 @ 18Gbps)
Corsair SF850 SFX PSU (850W / Platinum-rated)
280 AIO for CPU
GPU deshrouded / defanned, dual NF-A12x25 PWM fans added for exhaust in inverted mode
That would be a whole lot of compute power in a 15L package...!!!
Boil
1,253
1,094
@Boil I've been wondering for a while now... do you have a thing for ellipses?
I just feel regular punctuation is kinda crowded on the end of a sentence...! ;^p
That's a very valid concern but... have you asked yourself how many MP and charisma stats that awesome beard adds? That I want to know 😛
I am not at liberty to reveal the full extent of my power(s), but the stats your a curious about are well over 9000...!!! ;^p
  • Haha
Reactions: SiKiaTriK
Aluminyum
150
192
Heh...
That's a very valid concern but... have you asked yourself how many MP and carisma stats that awesome beard adds? That I want to know 😛
Asking the real questions.
Okay, so this thread has somehow turned into an M.2 vs SATA SSD debate.
Actually, it's about ellipses and beards.
Joking apart, back on topic...
Boil
1,253
1,094
Up to 1TB RAM
280 AIO for CPU
I was trying to bring it back on the topic of the C4-SFX (albeit with feature creep / volume inflation), but then was ambushed by the Punctuation Police...! ;^p
  • Haha
Reactions: Aluminyum
SFF Watercooled
399
172
Why is ATX PSU support needed? Surely most hardware can run on current 750w SFX PSUs and upcoming 850w+ PSUs?
1. Lower price (SFX PSUs are expensive, sometimes even scalper prices)
2. More wattage (For special use cases, but again it's still an option)
3. Always in stock (High wattage SFX PSUs are out of stock most of the time)
Revenant
Revenant Tech
1,746
2,859
Dan,
I know you've shown prototypes made out of metal, but I really need you to sculpt it out of marble. I would settle for granite but it needs to really draw out the character of the rock. Additionally, I need a small zen garden integrated into the top of the case. A water feature would be nice but not mandatory.
SFF Watercooled
399
172
Dan,
Umm... Do you mean a case made of MARBLE? Completely unfeasible because
  1. It's hard to carve marble
  2. It's brittle and easy to break
  3. You can't settle for thin marble... You have to make it like 20mm thick for it to work
Or do you just mean a solid block of marble with nothing inside?
Ghillie
25
52
This man is clearly an idiot, ignore his attention seeking on this sensible and mature thread
What you REALLY want are perforated 530 karat diamond side panels. I've recently learned that diamond is an incredibly versatile and strong substance that can easily be hammered into solid blocks and even shaped into useful tools like pickaxes and offensive weapons like swords. Imagine the durability and look of a bright blue mineral case!!!1! Dan do your research asap
Reactions: Revenant
ignsvn
By Toutatis!
1,782
1,712
Hi all, a reminder not to stray too far from the original topic. Light banter & meaningful jokes are always fun, but personal attack in any form is not. Debate about the idea, not the person. As always, sarcasm & troll are best ignored.
I already explained why I need additional slots for 2.5" drives. I am completely OK & understand if Dan decided to stick with 1 (the current revision). Obviously not a reason to start a forum war.
Boil
1,253
1,094
There should be ATX PSU support... According to dimensions it should fit, but cables should be harder
Keep in mind, there is a main power plug sticking out one end, and then al the cables out the other... SFX-L is supported, but recommended against for cable clearance issues, going full ATX will only make that much much worse....?
Don't forget the Silverstone 1kW SFX-L PSU...!
The quality SFX PSUs are Platinum-rated, so worth a little bit more...? But I feel the "scalper prices" is more a supply & demand thing right now...? Not a lot of supply because of the global pandemic, but when the supply chain is back on track, pricing should return to normal...?
Most SFF is ITX & single GPU, so wattage is not a huge issue; but we have 750W Platinum SFX, rumors of a 850W Platinum SFX, and the 1kW (that's 1000W...!!!) Platinum SFX-L PSUs...
Plenty of power for the most demanding of SFF rigs...?!?
Differentiating that higher-wattage PSUs are out of stock really isn't saying anything, those are the PSUs folks want, so of course the lower-wattage units are in stock, no one needs them...!
All in all, right now is kind of a bad time to be a SFF Enthusiast, due to uncontrollable supply issues & massive demand for components...!
Aluminyum
150
192
Am I the only one who's disappointed by the 132mm limit of the traditional layout? Personally, I can't stand both AIO coolers and PCIe risers, so I wish there were support for cards at least 135mm tall.
SFF Watercooled
399
172
In classic layout cases, the GPU cooler height is around case width - 20mm. In the C4, The estimated GPU cooler height would be 151mm - 20mm = 131mm, which is quite accurate. This goes for almost all cases, so 135mm and up can be implemented at the current dimensions, although it would suggest some changes (1mm steel, low profile motherboard standoffs required, etc).
@dondan, what is the height of the motherboard standoffs?
