Here are the preview results of the first test with the C4-SFX.
Testsetup:
- Ryzen 7 1700 @ default clock
- Asus Strix B350-I
- Nvidia Titan X (Pascal)
- 32GB DDR4
- Corsair 450 SFX
- Asetek 120mm AIO (27mm Radiator)
- 2x Noctua NF-A12x25
I used Prime95 (26.6) 8K run for max CPU load and Valley Benchmark 2.5K simultaneous. The case fans spin at 100%.
Radiator on Top
---------------------------------------CPU--------GPU Clock----GPU FAN----GPU temp-----Room
FAN push out - open------------50 °C------max 1800------2350 rpm------82 °C------25 °C
FAN push out - vented----------50 °C------max 1780------2380 rpm------82 °C------25 °C
FAN push out - Window--------52 °C------max 1780------2410 rpm------83 °C------25 °C
FAN suck in - open--------------50 °C------max 1800------2350 rpm------81 °C------25 °C
FAN suck in - vented------------50 °C------max 1780------2380 rpm------82 °C------25 °C
FAN suck in - Window----------52 °C------max 1780------2410 rpm------82 °C------25 °C
Radiator on Bottom
----------------------------------------CPU--------GPU Clock----GPU FAN----GPU temp-----Room
FAN push out - open-------------54 °C------max 1780------2380 rpm------82 °C------25 °C
FAN push out - vented-----------56 °C------max 1780------2400 rpm------82 °C------25 °C
FAN push out - Window---------57 °C------max 1780------2430 rpm------83 °C------25 °C
FAN suck in - open---------------52 °C------max 1780------2380 rpm------82 °C------25 °C
FAN suck in - vented-------------56 °C------max 1780------2410 rpm------83 °C------25 °C
FAN suck in - Window-----------56 °C------max 1780------2410 rpm------83 °C------25 °C
