![](https://i.imgur.com/WzQpROG.png)
Code:
Exterior Color NCORE 100 MAX: Dark grey, NCORE 100 MAX Bronze Edition: Bronze
Materials - Exterior Steel, Plastic, Aluminum
Materials - Side Panel Aluminum
Dimensions (L x W x H) Normal mode: 155mm x 212mm x 481mm (Incl. Protrusions),
Expansion mode: 172mm x 212mm x 481mm (Incl. Protrusions),
155mm x 212mm x 457mm (Excl. Protrusions),
172mm x 212mm x 457mm (Excl. Protrusions)
Volume: 15.80L, NCORE 100 MAX Bronze Edition: 17.54L
Motherboard Support ITX
Expansion Slots 3x PCIe Slot mounting
Drive Bays - 2.5" SSD 1
I/O Panel 2x USB 3.2 Gen1 Type A,
1x USB 3.2 Gen2 x 2 Type C,
1x Audio Combo (Audio In / Out 3.5mm)
Included Accessories 1x 240mm PCIe 4.0 x16
Included CPU Cooling Solution 120mm Radiator with 38mm Thickness x 1 (Custom PWM Fan Max. 2400RPM)
Included Power Supply Unit V SFX Gold 850W ATX 3.0
Pre-installed Fan(s) - Rear 120mm SickleFlow PWM Fan x1 (Max. 1800RPM)
Clearances - CPU Cooler 48mm
Clearances - Power Supply 100mm
Clearances - RAM 48mm
Clearances - Graphics Card 337mm x 62mm x 180mm (Normal, 3.0 Slot thick),
357mm x 79mm x 180mm (Expansion, 3.9 Slot thick),
(Maximum space including GPU power connector)
Cable Routing - Behind MB Tray 11mm
Dust Filters Side panels
Power Supply Support SFX
Warranty 2 years (Case), 2 years (Thermal Solution), 10 years (Power Delivery)
Reviews:
Overall impressed with this case. I should be able to fit my graphics card (its a 2.5 slot card but 319 mm). which is a big plus, as I have had a hard time finding a case that would support it.
setup looks relatively easy and I do like the custom liquid cooling setup it has. Hardware Canucks didn't like the placement of the front IO, but I think it shouldnt be an issue. The placement was probably done there so that the won't be cable spew coming out the top(which is the alternative place).
