I meant the C4. As far as I uderstood, the drivebay for two SSDs was on top of that "grill" above the fans?I don't follow you on this. Are you talking about the C4 or A4?!
Sorry, yea I was kidding.Looks like we’re back to the drawing board boys.
Why do you have a Corsair AM4 retention kit there? NZXT ships them for free if you buy their AIO from an official reseller. Also, X370 isn't worth it over B350. And you can overclock a 1700 to perform at 1800X levels so you don't need to spend extra.I have created a list of parts, could someone verify if this would be perfect for the case?
and if you have any suggestions to the list itself then go ahead and point it out for me
https://pcpartpicker.com/list/T7T2qk
I recommend not to buy the Asrock X370 or the Asrock B350.
The have the m.2 connector on the back of the mobo. This means the evo 960 m.2 ssd will get pretty warm.
Get a mobo that has the m.2 connection on the front with passive cooling, I think asus has this option.
That is correct, asus did not add the vrm's.
The power supply is also restricted, so I doubt if the APU's will be used (but I am not sure).
With a GTX1080 on his list it does not matter![]()
But just from genuine interest, if an apu was used on this mobo, how would it act? Would only the igpu not work? Or would the whole processor not work at all?
The only one I am aware that could tell us that is DAN.Could someone tell me when might the Kickstarter campaign start?
