Funding CustomMOD Nano 1.6L (based on Asrock DeskMini GTX)
Choose best style of venting holes - https://imgur.com/a/3rpoc
  • Total voters
    27
  • Poll closed .
Chrizz
74
81
Yes, not so good as we expected.
3. Aluminum is able to radiate the heat into the air better than copper because of its lower density
More tests in some weeks.
I'm pretty sure aluminium heatsinks perform worse, but I guess we will see soon from those tests.
thewizzard1
357
263
@sergiiua You need shrouds on those GPU fans, to force the air through the heatsink!
Also, have you considered heatpipes / heatplates? They can be ordered in an aray of standard sizes, for testing, and mounted to the base of a milled heatsink with indium (low-temp) solder.
Reactions: Chrizz and Soul_Est
sergiiua
Jan 11, 2017
1,156
2,057
Ukraine
www.custom-mod.com
Yes, 80mm fan with frame works better then two 65mm frameless fans.
Interesting. Can you share some links?
CC Ricers
2,235
2,558
Yeah, that brick looks humongo next to the case. It reminds me of this:
Looks real great, just wishing MXM cards were more affordable.
Reactions: owliwar
AleksandarK
/dev/null
May 14, 2017
703
774
All is ready.
1. 95mm fan (PLD10010S12HH) from MSI Twin Frozr 5 (MSI GTX 980). Just need to replace the connector with the standard PWM 4pin.
2. Aluminum heatsink 140mm x 11mm x 140mm. Height is good, just need to cut length to 130mm and width to 95mm, drill 4 holes.
Why you changed heatsinks from copper to aluminum?
sergiiua
Jan 11, 2017
1,156
2,057
Ukraine
www.custom-mod.com
Because 4 reasons:
1. Longitudinal ribs instead of transverse. Fan will work with all heatsink.
2. 15mm (18%) wider.
3. Aluminum is able to radiate the heat into the air better than copper because of its lower density.
4. More distance between the ribs. Better for low air flow.
AleksandarK
/dev/null
May 14, 2017
703
774
Because 4 reasons:
Ok then.
