Oh, thanks. It means 1.27L is the smallest possible case based on STX-MXM.That's a DIMM, not a SODIMM.
Yeah, I got a reply back and they were going to supply me some, but is sadly normal DIMM. Could we possibly use a DRAM to SODIMM module?Oh, thanks. It means 1.27L is the smallest possible case based on STX-MXM.
Adapter or riser?Yeah, I got a reply back and they were going to supply me some, but is sadly normal DIMM. Could we possibly use a DRAM to SODIMM module?
Turbine?Why no radial Fans for CPU and GPU cooler?
Eh, a 90 degree riser would be perfect, but I fear it would be taller than a DIMM itself.Adapter or riser?
Turbine?
Aye, it's sadly the same height as a normal SODIMM which doesn't improve anything in my case.30mm 90 degree riser
Just put over, heatsink is heavyHow did you manage to fit the custom heat sink onto the 1050? It looks great!
Yes, I just shared useless funny deviceAye, it's sadly the same height as a normal SODIMM which doesn't improve anything in my case.
Yeah, definitely, I wonder what I'm going to do here?Just put over, heatsink is heavy
For mounting on MXM I'll use 4 screws.
Trying to fit it in a case with less than 39mm of height.What is your target? <1L? Do you plan to use Asrock STX MXM?
It looks like there's a 4-5mm bit that could be shaved off, unless it's a multilayer PCB (and I haven't seen the back side)Aye, it's sadly the same height as a normal SODIMM which doesn't improve anything in my case.
At the top of the DIMM? There are some traces up there.It looks like there's a 4-5mm bit that could be shaved off, unless it's a multilayer PCB (and I haven't seen the back side)
And a custom PCB would probably be way too expensiveAt the top of the DIMM? There are some traces up there.
I wonder if I can ask a manufacturer to make me one...At the top of the DIMM? There are some traces up there.
