CONSOLE - 8.3L, 53mm CPU coolers, 2-slot GPU
Console | Sliger
Sliger Designs is a manufacturing company based in the United States specializing in computer cases and systems.
www.sliger.com
CASE
Grained & Anodized Aluminum front panel
Steel frame with Matte Black powder coat
343mm x 356mm x 68mm
8.3L
GPU
2-slot GPU up to 145mm tall x 330mm long
FANS
2x 120mm x 15mm fans behind GPU as exhaust
MOTHERBOARD
Mini-ITX
CPU COOLERS
CPU air coolers up to 53mm tall
STORAGE
No 2.5" or 3.5" support, M.2 drives only!
POWER SUPPLY
SFX or SFX-L PSU support
CONSWOLE - 10.9L, 75mm CPU coolers, 3-slot GPU
Conswole | Sliger
www.sliger.com
CASE
343mm x 356mm x 90mm
10.9L
GPU
3-slot GPU up to 145mm tall x 330mm long
FANS
2x 120mm x 15mm fans behind 3-slot GPU as exhaust
2x 120mm x 25mm fans behind 2-slot GPU as exhaust
MOTHERBOARD
Mini-ITX
CPU COOLERS
CPU air coolers up to 75mm tall
STORAGE
2x 2.5" SSD
POWER SUPPLY
UPDATE 11/20/19 - FIRST PICTURES OF PROTOTYPE
Most recent 3D model concept update:
OLD REV ALBUM
This is all preliminary!
Goal is to have these be inexpensive entry level boutique SFF cases. They are not intended to be the smallest; just to be easy to work with, fit almost any components, and be readily available.
Target price is either the CONSOLE at $125 ~ $149 depending on default options and if we want to include free shipping. CONSWOLE is going to be a $199 + options with free shipping.
Will only be offered in black, with either a black anodized or clear anodized ("silver") front panel.
Power switch is able to be moved to either side of case. There is built in support for one 5.25" bay, but not sure I will make that available to consumers.
Let me know your thoughts, anything I could change, ideas, etc.!
PS don't hate the name
OLD REV ALBUM
