I want to use the Pico-Box X7-ATX-500 power supply in conjunction with a dell 330W AC adapter. However, the X7-At-500's barrel connector is on the back of the PCB.
Thanks!
Edit: I also meant to mentioned that I want to power a R9 Nano & i7 5820k with this setup. Is this completely unreasonable? PcPartpicker puts the max TDP of my whole system at around 376W, but I'm assuming that it will never actually draw that much. If its unreasonable is there another way to power the system that would be better? I don't to build a case big enough to fit a bigger PSU.
- Pico-Box PSU: http://www.aliexpress.com/store/pro...PIN-DC-ATX-Power-Supply/211500_747813627.html
- Dell AC Adapter: http://www.my-adaptor.com/330w-dell-charger-w.html
Thanks!
