In the last few weeks, I have been trying to improve the cooling performance of my custom sff without breaking the sound barrier.
My case is a custom polycarbonate case with 70mm in height (the cpu cooler clearance is 49mm)
I'm on a ROG x570-i with a Ryzen 3900x. (Thermal limit set to the default 95°C)
The first cooler I've tried was the Noctua NH-L9a. With the 14mm fan idle was at 75°C and on full stress at 95°C with clock down to 3.3gHz.
With the same cooler, I've also tried a 25mm fan that I had (a really noisy Delta AUB0912VC -4E49) - idle at 58°C and on full stress 94°C with clock down to 3.9gHz. Spoiler alert that was the best result, but that fan peeks at 45DBA on specs (under stress is way more but I did not measure, probably a 55 or more) so not a solution I would like to keep
The cooler I'm currently using is instead the Cryorig C7 G with the Noctua NF-A9x14 (the fan perform the same as the stock, but it is slightly more silent). Idle at 63°C and full stress at 95°C with clock down to 3.7gHz. That is the configuration I'm currently keeping
With this cooler, I don't have enough clearance for a taller fan, so my last test was a bigger fan. I tested the Cryorig C7 G with the Noctua NF-A12x15 and, to my surprise, it was worse. Idle at 70°C and full stress at 95°C with clock down to 3.5gHz.
What other fan configuration could I try? My idea would be to go for either a more powerful 92mmX14mm or a 120mmX15mm. However, I need suggestions on what fans to try cause I cannot seem to find anything promising. I'm willing to compromise on noise, but I would not go above a 36dba on spec.
