Hi quick question, was planning a build using the LOP-12 psu, trying to determine how the psu switches on? Is it always on when power is connected so you would need a switch on the back or does it switch on when it detects current draw?
I’m building an X300 setup with an M.2 riser powered by a Mean Well LOP-300 12 V supply. I need a load switch (or MOSFET power switch) to completely shut off the 12 V to the riser. Any off-the-shelf modules or proven designs you’d recommend?
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
