Log BAOCASE Mini | 2.77L 7800X3D & 4060Ti & internal PSU(with X600-STX 12v input MOD)
sandyware
37
79
Hello, I've recently received the sister motherboard to this board, the X600TM-ITX. I'd like to do the 12V mod as well, but there is no tutorial for that anywhere. With some light inspection, it seems my motherboard uses the same power circuit as this, the STX. However, the position of the components on the TM-ITX are a little different:
I have a multimeter but no schematic. Can you tell me what the new 100K Ohm resisters are connecting to in relation to the PU23 chip? I can then trace out the connections and make the proper mod on my end.
I have no idea, the difference between the two board is very significant.
xsliquid
Hi @sandyware
Seeing if you had this problem with any of your builds, I did a resistor mod with a SMD 100K resistor in 0402. Running x600 board with the HDPLEX 250W and the 12v going to the barrel plug.
The system was running completely fine for a couple of days. Then the following day without any modifications, the system would shut off after about 2 minutes of usage. Then after getting it back on by unplugging power it would run about 5 seconds and then shut off again.
I tried two different HDPlex 250w GAN and both are unable to keep the system powered on long term.
System has a 9700X CPU and I did get it working with a RTX 4060 low profile with the GAN Also powering the video card. But after it started shutting down, I removed the video card so it is only running on the 9700X on board video and it still shuts off.
Is it possible the resistor mod isn't able to keep the system running stable with the 12v from the GAN?
Thanks for any input.
xsliquid
The longer I keep the system without power, on the next boot up the system is able to stay on for a few minutes more...
1,322
VIC, Australia
Do you have any other power supplies you can test? I.e. not an HDPlex
It would at least rule that part out!
What’s your PBO settings set to? I wonder if the 9700X trying to pull more than 65-90W and some sort of OCP is kicking in..?
Reactions: BaK
xsliquid
I guess I could try with a regular ATX. I don't have any other pico psu/meanwell
I set the bios to default several times. So I would assume PBO is off.
Also seems to be the time duration when it is on that causes it to shut down. As it has powered off when I was in bios and most the time in windows it's pretty much idling. Also did a 3 min prime95 test. It didn't power off until a few seconds after I stopped the test.
1,322
VIC, Australia
That actually sounds like CPU voltage issues, like what happens when you have Curve Optimiser too aggressive. i.e. It works fine under load but then crashes when at or near idle.
Maybe try setting a POSITIVE curve optimiser or a positive offset CPU voltage maybe? I can't remember what options there are in UEFI/BIOS.
Or even try forcing ECO mode or negative boost offset.
Otherwise yeah I'd see if you can jury-rig something to power from an ATX supply if you can.
sandyware
37
79
Could you show how you wired up the 8 pin to the 12v on the power supply? Did you just split 2 16gauge wires to the 3x12v portions of the PCIe 8 pin plug? And is there a single ground...etc.
3x12V pin ,and 5x GND pin, each soldered to the same wire
sandyware
37
79
Hi @sandyware
Does the USB port still have 5V output after automatic shutdown?
xsliquid
I didn't check. Unable to check anymore because it seems to have suddenly fixed itself.
Made two changes to the BIOS:
- PCIe Gen changed from Auto to Gen 4
- Fan speed from low noise to medium
I thought to change the PCIe gen because when I was first set up the system I was using an older Gen3 cable that didn't work at all. So I switched to Gen3 speed, but that riser still didn't work, but I had no shut down issues when using the onboard graphics.
Weird if that's the setting that fixed it... So really unsure.
Now it works fine... But it feels like there may be some slight video stuttering from using a riser cable. Don't know if I'm imagining or not.
Thanks @sandyware
1,322
VIC, Australia
Thanks @sandyware
Definitely strange as neither of those settings make any sense to changing it! But hey, if it's working it's working!
nmogv2
Michigan
An additional question:
Where are you stealing 3.3 and 5v for the black and yellow cables for the riser card? Or is the conversion handled on the riser, and you're just splitting a 12v and ground wire to the riser card input. In which case, any specifics on how which wire you chose to split from?
sandyware
37
79
3.3V is provided by the M.2 slot on the motherboard and directly connected by the riser cable. Riser only requires an external 12V connection, connect it to the PSU.
Blindmech
Would this work with the new 5060 as well? I saw Zotac is making a shorty version.
I wanted to try this myself with my deskmini x600. But right now that zotac 5060 costs the same or even less than any of the current used 4060 ti listings.
1,322
VIC, Australia
No real reason why it shouldn't - but nVidia is often doing weird stuff that breaks things so who knows
Blindmech
Yea thats pmuch the conclusion i came to in the past couple hours of researching. I Ordered all the parts needed, including a PCIe gen5 m.2 adapter. We'll see how it turns out. I'll definetely report back. Overall once everythings done it should end up somewhere between 2.7 to 3l
Reactions: SFFMunkee
Hello1732
Is there a more detailed way to explain the first option that requires the resistor? also a link to the exact ones any of you guys have used would be very helpful
Is this safe?
sandyware
37
79
The RTX 50 series requires a PCIe 5.0 riser connected to the front-facing M.2_1 slot. Both the 5060 and 5070 are compatible. PCIe 4.0 riser connected to M2_2 slot causing screen flash black.
protocolsix
29
All DC-DC circuits on the motherboard can work at 12V. All I did was lower the threshold for under-voltage protection of DC input.
Thank you for finding this mod and sharing!
Presumably the X300 predecessor lacked this under-voltage protection circuitry since it worked at 12V. It seems odd that ASRock would bother adding this complexity when the DC-DC circuits are *more* efficient at 12V input than 19V... any ideas why they would do this?
Reactions: Soul_Est
