Hello there. I see there's another convert that worries on the high VRM temp... Well, the same thing happens on my AB350 + Ryzen 7 1700X. Mine is 114 degrees C, LOL.Thanks everyone for the replies. I tried both HWiNFO64 and AIDA64, these are the results:
They look consistent, should I worry about it or do you still think it might be fine?
I'm on 1803 too, I'm fast lane Windows Insider as well... Boy the journey was nerve wrecking (had to redownload many apps and games I download from Windows Store due to bugs and just general beta experience). Anyway, the Core Isolation doesn't work on my side, does it work on Intel side?I'm on v1803, and this new version have new security options (Core isolation>Memory Integrity) but it doesn't work on my PC.
So I would like to know if others have that problem?
I never understood that numbers also. Frankly, my circle of friends and knowledge most are Intel users, and the AMD ones... Let's just say they follow the brand religiously. According to them, it's normal. With my 114 degrees VRM, the system runs optimally for almost 9 months now and I use my system daily, since I work from home. I do have a plan to move to 2700X, but not too thrilled with the increase in TDP and having to upgrade to new motherboard to utilize sustained frequency boost and XFR 2.0. Let's see if the new system also has that high VRM temp numbers.
TL;DR: it's fine.
Than add airflow, with a fan![]()
This is the same behavior I was seeing on my board, in HWMonitor it says 118°C and rarely changes, and then goes down when its under a heavy load. HWiNFO64 is supposed to be more accurate and I think it discards unreliable sensor readings so it doesn't show this sensor at all. My computer has been running over six months without issue so far.. so its probably nothing to worry about but It would be nice to know what the actual temperature of the vrms is.Though through some searching I did find someone mentioning that the VRM temps on this board seem to be interpreted incorrectly, showing lowering temperatures as the system heats up. Check this make sure. You could use a case fan on the VRM heatsink area to see if it indeed doesn't lower the temperature.
Maybe change your CPU cooler for a top-down one, that will blow on the VRM ?
What you could also do is remove the AMD fan and shroud from the heatsink and use a 120mm or 140mm fan above it (attached to side panel). Plug it in the CPU_FAN header, be sure to use a fan that's meant for heatsink use (not any generic case fan) because you want the static pressure.
It goes without saying that the amount of airflow will be key. You could try with the CPU fan at a higher speed (different profile or manual, in BIOS) to see if increased airflow with the current fan would lower the VRM temps.
But mind you that VRMs don't need to be below 100°C, they can handle more than that. Though through some searching I did find someone mentioning that the VRM temps on this board seem to be interpreted incorrectly, showing lowering temperatures as the system heats up. Check this make sure. You could use a case fan on the VRM heatsink area to see if it indeed doesn't lower the temperature.
My B350 Fatality itx shows 107C pretty much all the time on that sensor in HWinfo. I disabled that reading a couple of months ago and feel that it is inaccurate. The rest of the temp readings are more in line with what you would expect with my HW config. If your stuff is running well and everything else looks decent then don’t sweat it.
Here is my situation:
I dont have one available already so Im looking for something already tested before spending more money.
@nick_w
1) I tried with 100% fan mode and if the other temps gained maybe 5°c the vrm was stable.
2) I tried heating up the system in two ways. Gaming mode and stress test with AIDA 64 checking the temps with Hwmonitor and Hwinfo. I noticed a -3°c in gaming mode but the CPU wasnt really heating up so I moved to AIDA 64. There I noticed a more consistent reduction. On Hwinfo it went from 105°/106°c to 97°c. On Hwmonitor from 117°/118°c to 106°c. So it might seems that the temp goes down when it heats up. Does this mean those values are wrong then?
Ps: Unfortunately AIDA 64 crashed around min 27 with an exe error and I even had to manually reboot the system so I cant show a screenshoot with all the tables. What I dont get is AIDA 64 was showing a max cpu temp of 75°c even reported on the next boot. Meanwhile HwMonitor was showing 88°c and HwInfo 86°c under the CPU(Tcl/Tdie) but same as AIDA 75°c under CPU in the MB list.
You know my system is working good aswell from months but you never know if you are using it in the wrong way. We know that pc parts dont just fry quick but it might take a while :S
Did you hide the VRM temps aswell?
