Production Aquanaut Basic/Extreme - Ultra Low Profile CPU Block & Pump Mount Combo
2,201
2,225
such meme! 😅 👍
Come on, make one! You know you want to! You can probably get cheap vinyl skins made that will fit perfectly - you have all the design drawings after all. Come on, do it! Please? :D (Yes, this is clearly more important than your other work!😅 )
Of course, the best case scenario would be a collab with EK for custom-colored Torque fittings for each design.
And the design opportunities are endless! There has to be some Star Wars robot that can be adapted. (Or, god forbid, Jar-Jar?) Mrs. Potts from Beauty and the Beast? Sebastian from The Little Mermaid? Nemo? The dog from Up? I'm sure Disney are open for a collaboration ;)
Nouvolo
Creator
760
1,713
www.nouvolo.com
Anyone will be interested in a Al (black) DDC pump cover? (~6mm height)
for your reference, pump body is ~24mm (excluding impeller)
Update : seems casing is different for different brands e.g. EK vs Barrow vs bitspower, etc all slightly different...
Reactions: Allhopeforhumanity
Nouvolo
Creator
760
1,713
www.nouvolo.com
For_Science
447
613
Granzon GFM PWM DDC Water Pump, with digital rpm/flow meter (total height 40mm)
I like the concept and idea of having a display, but the displayed metrics are near useless to me. The flow rate is merely simulated and not a reflection of real flowrate, and everything else is simply a derivative of the incoming voltage.
Ideally it would actually measure water temperature, and an actual flow rate. These two parameters govern everything about liquid cooling.
Nouvolo
Creator
760
1,713
www.nouvolo.com
That makes sense, seems the extra height can just fit the screen and its electronics, but not the flow meter rotor for actual measurement.
A typical flow meter rotor :
MozzieT
Any updates on a preorder or when this will be available? Itching to get this system up and running :D
Also wondering how mounting kits for upcoming alder lake will be made available? Will they be available to order as a separate part?
max31092
76
45
Reactions: Talyrius
Brandon86
37
48
Eagerly awaiting this release!!!! Hope development is going well and still slated to be ready this month! About how many will be available in the first run do you think? Want to get one early, I have a custom loop waiting on this as an upgrade from my old aquanaut, since I switched to Intel and only have the AMD older version.
Nouvolo
Creator
760
1,713
www.nouvolo.com
Still waiting for cold plate delivery before going into packing. Will probably open to ordering in Sep and shipment (hopefully) in early Oct. May need couple weeks extension due to late delivery of cold plates.🙏
