Motherboard Anyone seen this? Udoo Bolt, a maker motherboard with Ryzen SoC
Hifihedgehog
Editor-in-chief of SFFPC.review
May 3, 2016
459
408
www.sffpc.review
Yes in Aibohphobia's STX160.0 thread! Good show reminding us of that.
Could someone jog my memory? Is the practical limit for gaming with 4 PCIe 3.0 lanes around a GTX 1060/RX 580? I don’t recall where the point of diminishing returns was in terms of bottlenecking of frame rates. I might consider something like this in the future if I could whip up a 3D case and use a GTX 1060 or equivalent. It is just a possibility I am considering, especially given the potential portability benefits.
KMPKT
3,382
5,936
Hifihedgehog
May 3, 2016
459
408
www.sffpc.review
Ah... That sounds excellent! I actually remember now where I was thinking of the bottlenecking conundrum—Thunderbolt 3 and dual-core Windows tablets. As I recall vaguely on the Eve Community forums from a year or so ago, someone had posted test results of scaling with either an Asus Transformer 3 Pro or the Eve V. They had found that the GTX 1060 was the practical limit due to CPU bottlenecking.
thewizzard1
355
261
Man, I'm so close to backing this... This looks very fun for SFF brainstorming, but I also really want to snag an i7-8809g unit once those drop... So many decisions.
Anybody know if they mentioned if they will enable ECC support?
Reactions: Soul_Est
EdZ
Virtual Realist
May 11, 2015
1,578
2,108
With Thunderbolt, you have the additional hurdle that you are not using the PCIe lanes from the CPU, but those from the chipset. For both Intel and recent AMD (post Ryzen) platforms that means effectively the GPU needs to share a PCIe 3.0 link with all the other chipset-connected components, and on Ryzen all the chipset lanes are PCIe 2.0 only. The Udoo is using the V1000 embedded SoC, so there is no chipset. Instead, those 4x 3.0 lanes come directly from the CPU.
PCIe bottlenecks in GPU performance mainly scale with framerate rather than GPU performance (i.e. the more frames you render per second, the more 'chunks' of data need to pass from the CPU to the GPU). As the V1000 CPU is pretty slow, you're unlikely to be reaching a high enough framerate in the first place for PCIe link bandwidth to be the main limit of performance.
Reactions: Hifihedgehog
Brian_Buckley
47
41
So with AM4 Mini-STX going to be a thing from ASRock, what features does this board offer that Mini-STX with a Ryzen APU won't? (other than the obvious downscale from 5x5 to 4.7x4.7).
It's way lower TDP so it can work with more limiting enclosures in general, but I'm curious what tradeoffs in features and performance you're getting for that size and power decrease.
7,745
This is more of a development/maker board with extra IO aimed at that market.
Kind of like the RaspberryPi versus a budget Linux box- they are both usable, but the box isn't as Dev friendly and the RPi wouldn't have as much outright performance.
jØrd
S̳C̳S̳I̳ ̳f̳o̳r̳ ̳l̳i̳f̳e̳
sudocide.dev
LOSIAS
Jul 19, 2015
818
1,359
To expand on what @confusis said, this board has an Arduino compatible header on it, 3 grove connectors and an IR header.
EDIT: also it has a header for SATA power on the board, eMMC and an ATmega 32u4 on it
CC Ricers
2,234
2,557
Did you get to see if the mounting holes for the APU cooler are compatible with 3rd party coolers? I don't know what the typical layout is for the embedded Ryzen/Vega chips.
chinevo
SFF Recordsman
May 11, 2017
158
278
Any ideas? How high are the elements under the motherboard?
