Hi SFF-Forum,
im having really weird temperature issues with my build below:
SilverWolf (Skyreach 4 Mini)
https://au.pcpartpicker.com/user/HYPERTiZ/saved/Lcyr7P
This is with MCE, Turbo & Sidestep disabled.
i5-8400 & Noctua L9i idle Temp in a Skyreach 4 Mini (R2)
EDIT - TLDR - Problem was the fact that the Heatsink orientation is in reverse meaning (the gap that was intended for the m.2 slot's height) was giving the cooler an elevated position with the M.2 slot. flipping it around (fan too for convenience) fixed the temp issues... - Thank you everyone for your help especially (NFC) Josh for suggesting whether it was installed backwards!
im not sure if its related to installation issues because of the m.2 slot and installing it while inside the case?
or a slightly bigger than pea sized paste or its terrible spread with the cooler?
Because when I install the Intel Stock Cooler it hovers around 39-45c idle - a much more realistic and safe temps and running with turbo never exceeds 80c which means its doing its job. I find it strange how many other coolers I never had problems but this is the most frustrating cooler I had ever installed - temp wise.
