Oh good. Now we are getting some good questions! Maybe I over-reacted with the 6 mm walls. My normal small prints with my normal nozzle and 3mm walls are plenty strong.
Here's the problem. Since the case was so large, and my nozzle was clogged anyways, I switched to a 0.6mm nozzle. In S3D it sets the extrusion width to 0.72. So I get two inside shells of 0.72 and two outside shells of 0.72. There's a gap of .12mm where the infill should go, only there's no infill. For those of you who were wondering, the infill was set to 20%.
So help me out here. What do I do?
Once I get the infill situation worked out I could use PETG. And no, I've never ripped chunks out of the PEI with PETG. The CR-10S has a metal hotend, so I could even use more exotic materials if that made sense. The gray stuff is standard PLA.
I don't think I can afford a laser cutter. And I never heard of Ponko. I'll have to check them out. Would you combine that with 3D printing for the corners, etc. or would you use finger joints?
Here's the problem photo...
Mike...
Mike...
