3051-1 HC NAS Node6 (what a name!)
Ceros_X
747
660
US
I came across this yesterday while browsing AliExpress: 3051-1 HC NAS Node6
It isn't a tiny thing coming in at 17 6L, but it dies support an ATX power supply, 6x 3.5" HDDs, 165mm high CPU cooler and double slot graphics card (although judging from the website you may have to remove 2 HDD mounting points in order to use a graphics card longer than 160mm).
It too shabby, and all the panels are held on by clips/studs. I wonder what you could do using an SFX PSU?
Anyone else know of any similar SFFish NAS cases?
Edit: a lot more detailed pictures on their AliExpress listing than on their company site, which is weird. Also it was a PITA to find the actual link on their website..
Ceros_X
747
660
US
Looks like a knockoff of the Fractal Design Node 304. Internal frame design appears identical, main difference to the outer shell is the USB placement and a more basic fan opening design (directly punched in the shell rather than inserts).)
Good catch! Not familiar with the Node 304. The ripoff seems to be 2L smaller, weirdly enough.
