Production Сase MINI 3.8L by Custom_MOD
dananglabs
Indonesia
Is GPU compatibility the same for this 3.2L as it was for the last one? The best that fits is a 1050 Ti?
My 3.2L is the second batch, and can fit the 1070 aero..... i wonder why the current batch does not fit these cards..... I want to order again but i just notice the compatibility gpu cards for current 3.2L is not fit for the 1070..... hm...
QuantumBraced
507
358
It's always very confusing with CustomMod. Earlier in the thread I asked about the new 3.2L and whether it would fit those longer cards, then sergiiua said there won't be a 3.2L with this version, but rather a 3.7L. Now it turns out there is a 3.2L but who knows what it fits. It's all so messy. But no other manufacturer wants to make these tiny cases.
Reactions: Mtthwmths
sergiiua
Jan 11, 2017
1,156
2,057
Ukraine
www.custom-mod.com
case M3 mini hdp 4L rev.0.1
Specs:
- Volume: 4L (110mm x 190mm x 190mm)
- Material: Steel frame (1mm), aluminum covers (1.5mm), Powder Coating
- MB: mini-ITX (170x170mm)
- GPU: length <173mm, height <132mm, thickness < 38mm Compatibility table
- CPU Cooler: up to 40mm (Noctua L9i compatible)
- Storage: SSD/HDD: 1 x 2.5" 5-9mm
- PSU: HDPlex HiFi DC-ATX 400W / pico HDPlex 160W
- PCIe riser: LiHeat 300mm D.type
Reactions: loader963
yensteel
32
30
Expanding on the idea, do you think it would be a conceptually good idea to slightly increase the size of the GPU chamber and fit a HDPlex 400w AC-DC power supply in the place of the 400w DC-DC power supply? It would then allow the case to fit a 1080 Ti mini as a brickless build when paired with a G-Unique psu. Alternatively a DC-DC psu can be fitted in the space next to the motherboard. Venting and airflow management may need to be taken into consideration though.
Anyways, with the current 4L design you can fit a 200w Meanwell Psu instead :D
maro
Hi, I really want to buy case M2 mini 4L rev.1.1
Is it available now? Also, is it possible to ship to Korea?
I look forward to hearing from you soon.:)
sergiiua
Jan 11, 2017
1,156
2,057
Ukraine
www.custom-mod.com
case M2 mini 3.9L rev.1.1
Specs:
- Volume: 3.9L (115mm x 190mm x 185mm)
- CPU Cooler: up to 50mm (CRYORIG C7 compatible)
- PSU: pico HDPLEX DC-ATX
sergiiua
Jan 11, 2017
1,156
2,057
Ukraine
www.custom-mod.com
I got this power supply from 400W HDPLEX! It looks amazingly reliable. I am delighted. Now I can design a case for it. Would you like a case like this?
jyUs6oV3Re8lHJ2bUFsk1RMYlgrhuzIGCK9jq8ynRsTeTDBepavO8kkvLKDkRGtZa5NrNiLO3ROQ6RW9VWrgs68oEDG-3ONAvLINj1lHzywrCMopMnAVcve1OrlCXwLzSRxmLUxMrRUWniM
TqD6lcBQwT9639PYApPfyKom6xLH9ZSzBbBBdGWB9Vor6hGfHGmF-pZzEDMzWrLF7GCCJKAAJvFk_-OTYgK401z0Z6U8P4NRUISD4y6WJR5H2epXnbIvXgw_W4e5aTuVpbShNAUhJTEERHE
